Interior/Exterior The Official Mad-Modder Club
#177
Lets See... (updated)
MagnaFlow Exhaust
Injen Intake
Painted Black Interior Pieces
JCW carbon boot handle
Changed Interior from Silver to Anthracite
Installed a Eclipse Double Din Lowering A/C and toggles
Installed Sport Seats (From Non-Sport Seats)
Installed SilverStar Headlight Bulbs
Installed an Autophage Alarm System
Aesthetic Creations sunvisor decals
Aesthetic Creations Checkered Side A panels
Interior lights Changed to Neon Green
Craven Speed Shifter Cover
Alta Short Shifter kit
Ultik Pedal Covers
AVN Double Din Indash (Navi, DVD, MP3)
Alpine Type S rear speakers
Drilled Rotors
There is more to come....
MagnaFlow Exhaust
Injen Intake
Ultik Pedal Covers
Drilled Rotors
#179
Hell...I think you just took my position away...
I'm going to print up your list and when people asked me how much I've put into Msfitoy, I'll say "not enough" while I show them your list...
I can't believe I didn't see this thread before...ok, I'll bite...
I prefer to think of my illness in terms of “stages of insanity”:
Stage 1: Simple stuff
Cupholder (very clever design...can't remember the maker)
Custom pin striping
Black downtubes
Glove box organizer
Side reflector covers (makes them darker)
Alta shorty antenna
LightinSight Fresnel lens (on front windshield)
XM Receiver
Digital compass (mounted above rear view mirror)
Emergency glass breaker (hammer) mounted in glove compartment
No-holes Front license plate holder
Tow Hook
Belt line blackout
Stage 2: Do-it-yourself
Tiburon shift boot
Alta short shifter with custom “sheath” (to make the shaft thicker)
UUC Shift ****
UUC pedals
Ians auto-up circuit with DSC disable
Second row of toggle switches
Dension icelink ipod adaptor with custom door mounting
Promini guages (oil pressure & boost)
Custom carpeted rear storage system with 4 hidden toolboxes
JCW Seats
Scroth Quick-fit Harness Pro (removable)
Fire extinguisher mounted to passenger seat near floor
Wireless 4-camera system with digital recorder
G2X Data logger
Tach adapter for G2X
G2X oil temp sensor
Wide band O2 sensor connected to G2X
Detroit Tuned bypass valve
M7 60mm throttle body
GRS Intercooler
JCW Exhaust (dealer installed)
JCW Supercharger (dealer installed)
JCW 380cc injectors (dealer installed)
TRS engine damper
Detroit Tuned Tensioner Stop
JCW Rear Wing
Additional front driving lights (dealer installed)
Aero side skirts
Oricari intake vents
Promini stud converstion kit
Promini aluminum lug nuts
Promini spacers
SSR Comp 16x8” lightweight wheels (...and a separate set for track events)
Yokohama Parada Spec tires 225x45R16
Stage 3 Professional Help (thanks BHS!)
Detroit Tuned big brake kit with SS brake lines + hawk pads
Power Slot rear rotors + ferrodo pads
SS rear brake lines
Rear Caliper Bushings
Leda adjustable coilover suspension
H-Sport Camber plates
Webb Ultimate rear swaybar
Alta lightweight rear control arms
Alta adjustable front drop links
Alta Positive Steering Response system
M7 Strut Tower Brace
M7 Under strut system
Quaife LSD
Spec stage 2+ clutch
Lightweight Flywheel (15lb)
Alta 15% Pulley
Alta 2% lightweight crank
GP Spark Plugs
Alta air intake
AMSOIL Large Air filter
Oil cooler
Poly engine mounts
MTH tune (mostly for the rev limit adjust)
Apexi piggyback controller (adjusts timing)
Alta oil catch can
MSD Ignition Coil
MILLTEK Header
Webb ported head
Schrick Cam
Stage 4: Over the Edge (BHS again...)
Custom lightweight, high strength, coated pistons
Custom lightweight connecting rods
(Rotating assembly balanced together)
Alta progressive Water/Meth injection system
Injector duty cycle measurement attached to G2X
Brake ducts attached to Aero front bumper
BHS engine plaque
And a dyno tune to make it all work together...priceless!
Custom pin striping
Black downtubes
Glove box organizer
Alta shorty antenna
XM Receiver
Tow Hook
Belt line blackout
Tiburon shift boot
UUC Shift ****
UUC pedals
JCW Seats
G2X Data logger
G2X oil temp sensor
GRS Intercooler
TRS engine damper
JCW Rear Wing
Aero side skirts
Promini spacers
SS rear brake lines
Quaife LSD
Alta 15% Pulley
GP Spark Plugs
Alta air intake
Oil cooler
Poly engine mounts
Alta oil catch can
MSD Ignition Coil
MILLTEK Header
Webb ported head
Schrick Cam
BHS engine plaque
#180
on
No, I'll run for office in the next term...And as they say in the asylum (i.e. "home sweet home"): No matter how crazy you think you are, there's always someone crazier.
Some more important questions:
When is the next club meeting?? (and where?)
Do we have a club house?
Do we have a secret hand shake?
#181
Yes, your house has been declared the Club House. We expect at least three kinds of cheese (Velveeta is NOT cheese), lots of fresh fruit, no less than 8 bottles of imported wine for Europe, and 8 cases of beer (no cheap stuff). Have it ready for the next meeting (see the note above for time).
You'll find out at the meeting. Just don't wear any briefs, makes the handshake very difficult.
#182
#183
Engine:
Nology Hot Wires
IK22 plugs
Chrome caps for spark plug wires
Cubby chrome plates
Blue Samco Hoses
Screamin Deamon Coil Pack
Moss/aFe Intake
TSW Engine Damper
Forge Power Steering Tank
Forge Header Tank
M7 OCC
Milltek Exhaust--for sale
Megan Stainless Exhaust
Custom Painted Engine Covers
Blue Anodized Fluid Caps
Blue Anodized Wings Dip Stick
Custom Painted Transmission Mount
Steering pump fan shield
Craven Speed Short Shifter
M7 air diverter plate
Suspension/Handling
H-sport Springs
Minspeed 19mm Swaybar, with zerk fitted bushings and lock rings
M7 Strut Tower Plates
BMP Strut Tower bar...now hanging on my wall
Hotchkis New Generation Adjustable Camber Plates
IE adjustable rear control arms, upper
Megan Racing adjustable rear control arms, lower
Alta adjustable rear control arms...never installed, sitting on a shelf
Polished rear stress bar, not currently installed
Ferodo 2500 pads
Zimmerman Cadmium Plated drilled and Slotted Rotors, front and rear.
s-heavies with 215-40-17 Parada Spec 2's, sitting on my wall for decoration
Kosei K1 Racing with Exclaim UHP in 215-45-17, needed a quieter ride
Custom matched center cap stickers
custom alignment, front=negative 2 degrees camber, 1/8" total toe out, rear=negative 1.5 degrees camber, zero toe.
Exterior
OEM new 2006 Xenons with 6000K D2S bulbs
White bonet stripes
Custom Yin Yang sun roof graphic
Aero Kit rear roof spoiler
Craven Speed super stubby antenna
Color matched Indi Blue antenna base
Chrome rings around top hood vents
White painted side vents
Crystal side blinkers, silver bulbs
Moss Angle Eye front singnals
Euro tails, OEM style, clear signals in place of amber, rest is red
blacked out arch side markers
S-side sills
John Cooper Works sill plates
S chrome gas cap
2005 chrome grill surround, and 3 slat chrome center, Indi Blue lower slat, with 2005 lower surround (smooth style)
Interior
iPod Interface
Craven Speed iPod holder
Euro Parcel Shelf
Center Dash Cubby
Glove Box Cubby
Dual cup holder Coin trays
Euro arm rest
Dyna mat over the entire interior
Lapis Blue sport seats in place of Cordoba Beige standard seats
Blue and Tan Coco Mats
Ostrich Leather door cards, dash, steering wheel, shifter boot
Whalen shift ****, #10 ball, #2 ball, and custom engraved Yin Yang
2 tone rear cards with chrome accents
Touareg LED torch light in Cigarette Lighter holder
Boot Storage Bin
20% Tint
Door Pocket liners and dividers
Aluminum pedals and dead pedal
Blue Cockpit Specialties face plates
Indi Blue door bolt plug covers
Schroth Harness, driver's side only, currently hanging on my wall
Chrome rings on dash vents
Chrome covers on dash light button and emergency button
CD Changer, currently in my cabinet
Chrome Toggle caps
Full Toggle bay, all 6 switches, several are dummy switches
I am sure i have forgotten some stuff over the past 4 years, there have been many changes. ....and yes, I did all the work myself, interior, exterior, suspension, brakes, and engine bay.
Garage/Home
MINI Cooper Office Chair, with working seat belt
MINI Cooper hood on the wall with Xenons/LED lights that turn on and off with the garage door opener, plenty of car parts on the walls.
Painted to match Cabinets, Grey, dark blue trim, and white panels.
Nology Hot Wires
IK22 plugs
Cubby chrome plates
Blue Samco Hoses
Moss/aFe Intake
TSW Engine Damper
Forge Header Tank
M7 OCC
Suspension/Handling
H-sport Springs
Ferodo 2500 pads
Exterior
White bonet stripes
S-side sills
S chrome gas cap
Interior
iPod Interface
Euro Parcel Shelf
Center Dash Cubby
Glove Box Cubby
Euro arm rest
Boot Storage Bin
20% Tint
Chrome Toggle caps
Garage/Home
#185
on
Club Officials??
Did I miss something, has there been a president elected by the Supreme Court again?
I really need to peek out from under this rock more often I guess.
BTW, lets have a Mad-Modders meet at MITM if you will be there, I will...
#187
updated my list with pics
#189
Engine:
Nology Hot Wires
IK22 plugs
Cubby chrome plates
Blue Samco Hoses
Moss/aFe Intake
TSW Engine Damper
Forge Header Tank
M7 OCC
Suspension/Handling
H-sport Springs
Ferodo 2500 pads
Exterior
White bonet stripes
S-side sills
S chrome gas cap
Interior
iPod Interface
Euro Parcel Shelf
Center Dash Cubby
Glove Box Cubby
Euro arm rest
Boot Storage Bin
20% Tint
Chrome Toggle caps
Garage/Home
Nology Hot Wires
IK22 plugs
Cubby chrome plates
Blue Samco Hoses
Moss/aFe Intake
TSW Engine Damper
Forge Header Tank
M7 OCC
Suspension/Handling
H-sport Springs
Ferodo 2500 pads
Exterior
White bonet stripes
S-side sills
S chrome gas cap
Interior
iPod Interface
Euro Parcel Shelf
Center Dash Cubby
Glove Box Cubby
Euro arm rest
Boot Storage Bin
20% Tint
Chrome Toggle caps
Garage/Home
How did you paint your engine bay bits? I would love to do the same.
#190
bought the color paint from MinSpeed, comes in a rattle can, primed with engine temp primer, and the white paint is engine paint. All clear coated with duplicolor engine clear.
make sure to sand everything down first, and prime it really well.
#191
hm... my list isn't as exhaustive... but its getting there:
2003 MINI Cooper S, 10/02 Build
Canadian MCS, no options
engine: Webb Motorsport HDI,
Alta 15%,
Alta Oil Catch can Blue,
Screamin' Demon Coil Pack,
Livewire ignition wires Blue,
NGK BKR7EIX spark plugs,
Scorpion exhaust,
Alta 2% crank pulley,
MTH 91 octane,
GRS intercooler,
OBX header on OEM cat,
Engine damper
Pilo Short Shifter
Suspension: H&R RSS Coilovers,
Alta rear lower control Arms,
H-Sport Competition Sway bar Rear,
Wilwood 12.16 Street BBK
Wilwood Q pads for street, A Pads for track,
Ferodo DS2500 Rear brake pads,
M7 Strut brace silver,
M7 USS, Alta Endlinks Rear
Exterior:
Orciari Rear spoiler,
Rota Subzero 17x7.5 Royal Black, Falken Azenis RT615 215/45-17,
BSA 303 Silver 16x7, Hankook Ventus Z214 C50 205/50-16,
M7 lower grille,
4k halogens,
stealth turn signals front/side,
JCW taillights,
Alta antenna,
white parking lights,
PIAA 004X fogs,
OEM trunk protector,
OEM tow hook gloss black,
M7 CF ram air scoop CF,
M7 upper/middle Grille,
Helix Stud kit with Muteki lug nuts,
35%f, 20%r tint,
M7 Front splitter,
Dark Grey 'S' decal
Interior:
Alpine CDA9843 HU,
Sparco Rev driver only,
Scroth red quick fit harness,
Rspeed chrome rings speedo, tach, shift ring,
OEM rubber floormats,
OEM e-brake tray,
redlinegoods.com leather shift boot, ebrake boot, door handles, armrest, and center downtubes
MINI Mania center storage unit,
Alta Gauge pod, Greddy SMI gauges Oil Pressure, Boost,
Amber LED Interior lighting,
OEM Plastic boot mat,
Cobalt rear strut brace,
Custom Aluminum Pedals
Coming soon includes Quaife LSD, Fidanza Flywheel, Clutchmaster clutch, Autopower Rollbar, Sparco Fighter on the passenger side, Sparco 3' harness for the track use, the winter will then be used to make some repairs on the car, such as new pads for track and street, new Yoki A048 for track, among other mods... i really should end this game of mine:
this is when she's barely a week old
a much more recent picture
Alta 15%,
Scorpion exhaust,
MTH 91 octane,
GRS intercooler,
Engine damper
Pilo Short Shifter
Exterior:
M7 lower grille,
4k halogens,
JCW taillights,
Alta antenna,
PIAA 004X fogs,
35%f, 20%r tint,
M7 Front splitter,
Dark Grey 'S' decal
Interior:
Alpine CDA9843 HU,
OEM e-brake tray,
#192
on
Engine:
Nology Hot Wires
IK22 plugs
Cubby chrome plates
Blue Samco Hoses
Moss/aFe Intake
TSW Engine Damper
Forge Header Tank
M7 OCC
Nology Hot Wires
IK22 plugs
Cubby chrome plates
Blue Samco Hoses
Moss/aFe Intake
TSW Engine Damper
Forge Header Tank
M7 OCC
#195
Thanks!! I will look into that!! where did you get the white and the primer? a car parts store i would assume.
#196
combination of Pep Boys and Auto Zone, they all have the same stuff, just had to go to 2 stores to get what I needed since not everything was in stock.
#197
Well, this past weekend I put on the Angel Eyes and the thrid brake light pulsar. Now my Angel eyes match the Zenons.... The strobe effect of the thrid light is very brigh at night... I am so happy with them.
Art
Art
