Interior/Exterior Colored brake handle & shift knob replacement
Old Jun 22, 2007 | 08:55 AM
dnashcraft's Avatar
dnashcraft
Colored brake handle & shift **** replacement
has anyone replaced their brake handle and shift **** and have any instructions and/or tips for doing this? Any advice would be appreciated before I go breaking things. Thanks.
Old Jun 22, 2007 | 09:10 AM
bamatt's Avatar
bamatt
The shift **** is easy... just kneel over it & give it a big tug upwards. It will come right off but be careful because you can easily konk yourself in the head
Old Jun 22, 2007 | 09:18 AM
TwistySister's Avatar
TwistySister
Yeah, I've done the **** three times now. I've put it in neutral, opened the sunroof, pull straight up - hard! The dealership said put it in second. I have no idea why. Maybe it's an easier angle to pull.
I've also had the e-brake handle apart twice. It's not real hard, but there is a little clip inside (after you romove the tip cover). You have to carefully pry it to get it to come apart. Then it all slides off. Putting it back together you just have to line up the groove correctly. There are probably instructions somewhere on NAM that explain it much better than I can. Good luck!
Old Jun 22, 2007 | 10:26 AM
bamatt's Avatar
bamatt
oh & p.s... there is absolutely no need to take your shift **** off unless you are replacing it with a Whalen
Old Jun 25, 2007 | 07:36 AM
cube17576's Avatar
cube17576
Coordinator :: STLMini
http://www.redlinegoods.com/MINIinstall.shtm
Old Jun 25, 2007 | 07:50 AM
TwistySister
First time, OEM chrome bezel. Second time, blue leather shift and e-brake boots. Third time, Checkered Whalen. I guess what is often said is correct - "Third time is the charm!"
dyeLucky
Sep 11, 2015 10:41 AM
Mini'mon
Aug 16, 2015 04:15 PM
dyeLucky
Aug 7, 2015 07:10 AM
PelicanParts.com
Aug 4, 2015 02:45 PM
