Interior/Exterior Boot power outlet?
Old May 22, 2003 | 08:56 AM
chollomo's Avatar
chollomo
I've noticed that soem people on this site have pictures of a power outlet ( cigarette lighter power) adapter in the BOOT/Trunk... I just have a piece of round plastic where one would be, i feel a bit jipped this would be a great feature to have. is it some sort of add-on, why was it taken out of the design?, does it come with some sort of package that I am not aware of? How easy would it be to add this feature on? is there already the power wiring back there... THANKS ! :smile:
Old May 22, 2003 | 09:00 AM
Gabe's Avatar
Gabe
This was standard on '02 cars and was taken off all '03 cars. I've heard rumors that it may show up again in 04.
Old May 22, 2003 | 10:30 AM
VAmini's Avatar
VAmini
If it shows up again in the '04 model I will be pi$$ed! I wanted that so badly!
Apparently for the '03 they totally removed the wiring for the outlet, so to get one put in is a pretty major event.
Old May 22, 2003 | 10:34 AM
Minae's Avatar
Minae
Not on an MCS it isn't. The battery is right there, and running a short wire from the socket location and connecting it to the battery can be done with a single crimping tool available at almost any auto parts store. If you crimp on spade clips to connect to the parts available from Classic MINI, you don't need to use a soldering iron or any other tool. Deciding where to connect a hot wire (I used an inline fuse to go directly to the battery terminal) is the hardest part.
Old May 22, 2003 | 01:13 PM
chollomo's Avatar
chollomo
doh! what a great littel option too I'd so liek to have one!.. great for tail gatting adn the beach.
Old May 22, 2003 | 01:38 PM
sndwave's Avatar
sndwave
Coordinator :: Gulf Coast & Panhandle MINIs
I find it hard to believe they (MINI) would rewire the harness. If you pop your hand up the little cubby hole, I bet you’ll find the wires there.
With a 02 MCS I do have the outlet and I’ll bet the 03’s have the wiring, just not hooked up.
Old May 22, 2003 | 01:49 PM
Minae's Avatar
Minae
You'd lose that bet. I looked, no wires, nothing in the bundle that's not headed somewhere.
MINI killed the outlet to save money. I assume they have the engineering of the wiring harness computerized, and deleting the wire probably made more savings than deleting the outlet.
But it was a dumb move.
Old May 22, 2003 | 09:05 PM
vespa's Avatar
vespa
The outlet itself is under $5 and the wiring is NOT there.
See my detailed writeup
Old Nov 8, 2003 | 05:32 PM
lounytoon's Avatar
lounytoon
I think they traded the boot power outlet for the '03s for the prewired CD changer setup. The '04s don't are not prewired for a CD changer.
I have an '03...would love to have the boot power outlet also!
Old Nov 10, 2003 | 05:20 AM
minidreamin's Avatar
minidreamin
My 2004 MC has the power outlet in the boot.
Old Nov 10, 2003 | 06:32 AM
Skoobeedu's Avatar
Skoobeedu
The 04's have the outlet.... do they still have the pre-wire for the changer options? If not that is giong to make for a lot of extra work. Anyone know what the removable plastic plate is under the dash where the radio is?? under the "switches." I was peaking under there yesterday and I need to remove a bolt to check it out. just wondering.. thanks
67morris
Dec 1, 2015 12:53 PM
Filmy
Sep 7, 2015 11:27 AM
tylewis
Sep 6, 2015 01:07 PM
ou812_tugger
Sep 5, 2015 03:24 PM
Ntety
Sep 2, 2015 08:39 PM
