New ECS JCW Carbon Fiber Mirror Caps Gen 3 - OEM Design
Old Oct 25, 2023 | 10:41 AM
ECS Tuning
More New Parts Added!
OEM design, not peel and stick! This JCW styled accessory carbon fiber mirror cap gives you MINI an sporty appearance and a note to the racing heritage. Easy to attach, snap the old one out and snap the new one in.
Carbon fiber with clear high gloss finish.
Snap the old ones out, by removing the factory glass mirror first. This requires the ES#517779 schwaben trim tool, using the side mirror adjustment switch, turn all the way outward. Then pry and mirror pops out. This gives you access to the mirror front caps which when prying all tabs comes out.
**For vehicles with additional LED puddle light in mirror, small hold will need drilled to fit on driver side. **
** When installing these they tend to fit tight. Start from the inside towards the car and flex to snap on, then work your way outward. Working on a nice sunning/warn day and setting them in the sun first makes it much easier for install. **
Fits Gen 3 2014-2019 F54 MINI Clubman / F55 MINI 4 Door (5door) / F56 MINI Hardtop 2 Door / F57 MINI Convertible / F60 MINI Countryman
"Click HERE for the Gen 3 MINI Cooper Carbon Fiber Mirror Caps "
Sep 13, 2023 11:04 AM
mailmeamemo
Nov 12, 2016 08:52 AM
Davidoyo
Aug 26, 2014 09:06 PM
mdsbrain
Jul 19, 2005 05:56 AM
