Mini Cooper Interior Chrome & Armrest Kit Gen2
Old Jan 27, 2016 | 02:10 PM
Mini Mania's Avatar
Part No: G2NMK9000
SALE Price $279.00
Was: $379.90
You save: $100.90
Description
Interior Chrome Kit to dress up your MINI and the Italian Armrest for Comfort!
Fits the following models:
2007-2010 R56 MINI Cooper and Cooper S Hardtop
2008-2010 R55 MINI Cooper and Cooper S Clubman
2009-2010 R57 MINI Cooper and Cooper S Convertible
27-Piece Interior Chrome Kit
Chromed plastic overlay simply attaches over existing trim for simple installation.
  • This kit fits the above models with the single tachometer on the steering column. If you have the tach and speedo on the steering column, this kit does not include the chrome trim that fits the 'dual' gauge. Trim for the 'openometer' in the convertible is not included.
  • The Rear Cupholder Trim is not compatible on models with the Factory Armrest.
  • Speaker Trims only fit the 'Standard' sound system (non-Harman Kardon).
Kit includes:
Tachometer trim - 1 piece (single tach on the steering column)
Speedometer trim - 1 piece (center dash speedo)
Side defroster vents - 2 pieces
Side air vents - 2 pieces
Center air vents - 2 pieces
Toggle Switches - 8 pieces
Door Handles - 2 pieces
Center door speakers - 2 pieces
Lower door speakers - 2 pieces
Lighter trim - 1 piece
Cup Holders - 2 pieces
Gear shift trim - 1 pieces
Rear Cup Holder trim - 1 piece
Chromed plastic overlays attach with double-sided adhesive - included.
Note: If you have the 2009+ R57 Convertible, the tachometer chrome trim will require some modification in order to accomodate the openometer bracket.
Mini Cooper Ultimate Armrest
This comfortable Armrest from Italy is easy to install, works great, and looks like it belongs in your MINI. It is easily attached to the center console while still offering easy access to the handbrake. (For MINIs without the factory Armrest.)
Retractable pad with a storage compartment beneath, and a retractable cup holder. The entire armrest assembly can be 'flipped up' out of the way when not in use.
This armrest works even with the seat in the maximum forward position! Simply slide the armpad in the 'open' position to extend it's reach.
Fits models without the factory armrest:
Black Italian Leather pad with Black base.
Installation is simple: The Armrest bracket mounts into the rear cup holder with three screws (DRILLING REQUIRED for the 3 screws). The storage compartment's 'rubber feet' rests on the center console supporting any weight applied to the armrest. The design allows for easy access to the emergency brake handle.
If you are removing the factory armrest, you will need the Armrest Delete Kit to convert the center console back to original. Otherwise, you will have the old factory armrest mounting hardware exposed.
bighaus90
Jan 7, 2017 09:28 AM
natstalgia
Jan 2, 2016 04:04 PM
suss1173
Jan 2, 2016 08:16 AM
Suspension Products
Dec 31, 2015 11:18 AM
suss1173
Dec 31, 2015 04:50 AM
