:: ECS Tuning :: "MINI" Oil Storage Bag !
Old May 29, 2013 | 09:09 AM
It's here, the MINI Oil Storage Bag that states "MINI" !
Take one for the road with the Genuine MINI Oil Storage Bag. This handsome soft cover zippered bag holds a quart or liter bottle of emergency oil, just in case your engine ends up a quart low on a dirt road near Grizzly Gulch, Montana.
To keep you clean, the bag comes with paper funnels, gloves, hand wipes, and towels. Velco strips keep the bag attached to the trunk liner, conveniently out of your way, but ready for use in an instant.
Buy two; one for you, the other for a friend.
It's In the Bag.
Fits:
All MINI Models.
Click HERE to order or for more information.
Old May 29, 2013 | 09:15 AM
esfreerider's Avatar
esfreerider
can you confirm if this bag will fit a bottle of Liqui Moly oil? its shaped a little different then slandered quarts. If it fits Ill get one
Old May 29, 2013 | 09:38 AM
Is this the one you have? Liquid Moly has square bottle, which is one of the different shaped ones in the oil industry. We tested it and it does not fit. It fits most standard size bottles that match the OEM MINI bottle.
But this bag does have extras needed when topping off the oil and can be used for that in addition to other storage items.
Longtime High Tech Low Friction Engine Oil (5w-30) - 1 Liter
http://www.ecstuning.com/Search/LM2038/ES517884/
Thanks and hope that helps.
Old Jun 11, 2013 | 04:47 AM
Back in stock ! Great for the trunk.
Old Jan 14, 2014 | 01:17 AM
Ralph Mendoza Jr.'s Avatar
Ralph Mendoza Jr.
Did you ever find a bag that fit the Liqui Moly shaped bottle?
Old Jan 14, 2014 | 03:05 AM
minsanity's Avatar
minsanity
Just transfer the LM contents into a MINI/Castrol liter bottle & into that bag.....Easier solution.
Old Jan 14, 2014 | 04:44 AM
We tested it and it does not fit. As noted above on that 1 L Liqui Moly. Has to be very close to a Castrol MINI OEM container. Or you can transfer like mentioned above.
Jan 4, 2019 12:51 PM
minipopkart
Aug 13, 2015 05:22 AM
Aug 12, 2015 01:24 PM
Aug 11, 2015 11:58 AM
Aug 10, 2015 02:03 PM
