How To Another Aux Input DIY
Old 09-26-2010, 12:35 AM
robspec's Avatar
robspec
robspec is offline
looks good
  #52
Old 11-08-2010, 06:53 PM
spirit's Avatar
spirit
spirit is offline
thanks for the DIY
Followed all the instructions. everything worked out really well. I just needed to adjust the aux volume a little bit. Cost a total of $3.50 CAN ($2 bucks for the PC cable and $1.50 for the stereo jack).
Thanks for the posts!
  #53
Old 01-30-2011, 07:43 PM
06MINI-LNDS8PER's Avatar
06MINI-LNDS8PER
06MINI-LNDS8PER is offline
Works for me
I can't say how please I am with this project. It was so easy and works so well I don;t know how I ever made it with the stupid FM transmitters.
It cost me a total of $3 CAN at a used computer parts store and is probably going to be one of the mods I make the most use of.
Thanks for this walk though
Cam
  #54
Old 01-31-2011, 12:06 PM
Cole9953's Avatar
Cole9953
Cole9953 is offline
do you think it would be possible to this aux diy and the mini ipod adapter at the same time?
  #55
Old 07-26-2012, 08:54 AM
Leigh5t's Avatar
Leigh5t
Leigh5t is offline
Resurrecting an old thread here but i just wanted to say thanks!
My pre owned 2004 mcs came with a mini disc boost stereo and factory nav. I wanted to keep the original stereo but as mini discs are very much a thing of the past i needed an alternative. This diy guide has allowed me to retain the original euipment but have the luxury of my mp3's (whilst also keeping my money where i like best!)
The guide was very helpful and i did not require any resistors as many people have mentioned. I did however already have a plug in the socket where the aux needed to go (nav maybe). All i needed to do was remove the pins from the audio cable plug then insert them into the original mini plug....voila
Top forum guys, many thanks
  #56
Old 01-13-2013, 10:05 PM
dude17's Avatar
dude17
dude17 is offline
Just did this simple mod and without pulling the HU out I was able to plug it in from under the drivers knee panel as suggested. Just by feel it took a couple of tries to figure out which were the right pins since I could not see them, but once I had sound, I knew I hit gold. Thanks a bunch all!
One thing to note, I ended up putting a 1/8w 2.7kohm resistor between both + leads to be able to force AUX to come up regardless of what I plug in. I tried with just my iPhone and no resistor and it worked but when I tried the Belkin Bluetooth adapter I was going to end up using, it didn't so the resistor does the trick for all situations.
Now I have my iPhone streaming music via Bluetooth to the AUX port and I can also take calls and listen to the other end on my speakers! Simply AMAZING.
Should have done this ages ago.
rikaro
11-24-2015 02:05 PM
eliseo1981
11-02-2015 11:24 AM
M7Speed
10-01-2015 07:05 AM
Levers_and_Gears
09-28-2015 04:42 PM
Quick Reply: How To Another Aux Input DIY
