How To Maintenance :: Changing REAR Brake Pads for Beginners!
Old 05-22-2008, 04:03 PM
Gil-galad's Avatar
Gil-galad
Gil-galad is offline
Originally Posted by Goodwood
Harbor Freight in Memphis has these kits for $19.99 !!!!
It figures... I just plunked down list price two weeks ago.
  #77
Old 06-01-2008, 12:55 PM
OctaneGuy's Avatar
OctaneGuy
OctaneGuy is offline
HF is that way--they have sales all the time--sometimes you win some, sometimes you lose...but that tool is one of the rare HF tools that won't break the first time you use it, lol.
Yesterday I heard an awful scraping sound, pulled over, and realized that the sound was coming from the rear rotors. I pulled the wheel and found that the passenger side pad was worn down to the backing plate. The inner pad was fine--wasn't even worn down to the sensor.
Took me about 30 minutes to replace the pads and get back on the road. The HF tool worked great! It's not perfect--you have to align the pins, tighten the tool, crank the piston in a bit--it gets loose again--align the pins--tighten the tool, and crank it some more--making sure the piston boot doesn't get tweaked or torn.
Richard
  #78
Old 06-01-2008, 01:02 PM
Big Norm's Avatar
Big Norm
Big Norm is offline
awesome write up.....please post more projects as you come across doing them
  #79
Old 07-23-2008, 10:50 PM
koenner1's Avatar
koenner1
koenner1 is offline
damaging abs components
is there any danger of damaging abs speed sensors when changing the brakes? what should i be looking for and how do i avoid damaging it?
  #80
Old 07-24-2008, 10:12 AM
OctaneGuy's Avatar
OctaneGuy
Thanks! Certainly will!
Not that I'm aware of. Of course if you're aren't confident in your ability to change your pads, you probably shouldn't be doing it. I've given as much detail as necessary for any 1st gen MINI owner to change their pads.
  #81
Old 07-27-2008, 04:42 PM
jwulf's Avatar
jwulf
jwulf is offline
Great write up! Just finished my break job on the wife's Mini, I get a "thumping" that comes from both front wheels... I did all the rotors and pads...Brembo with the easy check dots on them and Hawk HPS... my thought is that the easy check dots are causing the noise...
Does anyone have an thoughts?
Thanks for the write-ups and any thoughts on this new issue (search didn't turn up anything anyway).
  #82
Old 08-04-2008, 02:43 PM
theradiantmini's Avatar
theradiantmini
theradiantmini is offline
Axxis Deluxe
dood, Octane man, you are my Mini hero!! any write ups on brake fluid flushing? Oh and I just scored front/rear axxis deluxe pads for one hell of a deal. check out http://www.r1concepts.com/
  #83
Old 10-14-2008, 03:11 PM
martyde's Avatar
martyde
martyde is offline
Brake pd sensor
Just in case you ever wanted to know, the brake pad sensor is nothing more than a loop of wire. Hence when it is contacted by the rotor and is worn through the ckt opens and the light comes on. If you do not want or cannot accommodate the sensor, you can take an old one cut it off at the connector end with about four inches of wire exposed, strip and connect the ends together. A little heat shrink looks nice as well.
Simple enough. Don't forget to turn on the ignition for around a min. to reset the dash indicator.
Marty de
  #84
Old 10-28-2008, 10:00 AM
mich.linux.guy's Avatar
mich.linux.guy
mich.linux.guy is offline
Thanks for the great writeup! It was a big help. I have a 2003 Mini.
Here are a few things I found while doing it:
If you are removing the rotor, the torx bolt holding the rotor is a T50. If you try to loosen it but the rotor spins, take the lug wrench and wedge it between the caliper bracket and a couple of lug bolts that you reinserted. I had to use some penetrating oil and an impact wrench to get it loose.
The bolts securing the caliper bracket are 13 mm.
My local Murrays automotive let me borrow their brake tool set for free. (You need to pay for it, but they will give you a full refund when you bring it back.)
When I had done a rear brake job on a VW I used to own, I could spin the piston back in using needlenose pliars like one of the replies mentioned. I had no luck doing this on the Mini and had to use the tool.
  #85
Old 12-04-2008, 05:33 AM
MC 2's Avatar
MC 2
MC 2 is offline
Originally Posted by StartTday
Just another suggestion for those that don't want to use the harbor freight tool to push in the pistons. Its a great package which I plan on ordering, but I just replaced my brake pads using one of these.
Costs only $8 from an auto parts store and works fine.
Hi i just both one of these at napa autoparts 20$ and it d'int fit none of the pathen would fit so in the end i used a pair of long noze pliyer that worked just fine ..just to lest u guy no''' the rightup is still verry goooood..Thanks
MC 2
  #86
Old 05-03-2009, 04:24 PM
indraneelis's Avatar
indraneelis
indraneelis is offline
Three cheers for OctaneGuy.
Just finished the rear pads on my 05 MCS.
This post made my entire life super easy.
All I did in addition to the article was use some brakecleen - to clean the entire caliper assembly - and used some anti-seize on all contact surfaces.
Also - if you dont want to buy the brake tool - you can get one on a loaner program from Autozone - for free. You pay for the loaner (full price $55) and they refund you($55) when you return the tool - within 90 days.
  #87
Old 05-03-2009, 05:25 PM
OctaneGuy's Avatar
OctaneGuy
Great to hear!!! Thanks for the feedback!!
Richard
  #88
Old 05-24-2009, 09:09 AM
thebestbear's Avatar
thebestbear
thebestbear is offline
Minis must have different sized bolts holding the brackets. My 2005 MCS has 16mm bolts.
I was upgrading rotors as well as pads, so The first thing I did was spray penetrating oil on the torx bolt front and back (you can get the back of the bolt by spraying inside the rear of the rotor). It sat for 20-30 minutes while I prepped everything else. I losened the torx screw just a little, tightened it back, losened again a little more, tightened it back. About 20 times and they come out like butter. Don't rush it. The rust that's the worst is on the back side of the bolt sticking out of the rear of the hub.
  #89
Old 08-20-2009, 01:43 PM
475nM's Avatar
475nM
475nM is offline
great write up! I just did all four rotors and pads yesterday, and like many others got stuck on the right rear for around 3 hours trying to compress the piston with the HF tool. I wonder why that one is so difficult? Other 3 took less than an hour.
  #90
Old 08-20-2009, 04:50 PM
Hawkeye's Avatar
Hawkeye
Hawkeye is offline
I, too, have one of the HF kits but I have a disc brake piston tool by KD Tools of Lancaster PA which is designed fofr both domestic and import cars. When I installed CT's 3 weeks ago, I used this tool and was able to rotate and reseat the rear pistons with ease. I think you can find the tool at an auto parts store. My recollection is that I paid $12 or so in the mid-1990s. It fits on a 3/8" drive.
  #91
Old 08-21-2009, 06:30 AM
soccerbummer1104's Avatar
soccerbummer1104
soccerbummer1104 is offline
just a heads up, the harbor freight tool wouldnt work for me. it wasnt strong enough to compress that piston down. (i guess its possible my piston is jammed a little bit) so i bought a SIR tools air powered brake tool. Its what the head mechanic at the mini dealer suggested, and he says its probably the best on the market (and no i didnt buy it through mini, so he was not just saying that. he bought the one at the dealer for himself) Its ~$165 for the complete kit (model # ST9020), which still pays for itself. after 2 axel brake changes. Ill post my results when i change my brakes this weekend.
  #92
Old 08-28-2009, 09:14 PM
daewoni's Avatar
daewoni
daewoni is offline
Hello..
I found this tool: http://www.canadiantire.ca/AST/brows...per%2BTool.jsp
It has 1-1/2", 1-5/8" and some more bigger ones. I think 1-5/8" is too big for mini' rear caliper piston. I'm not sure if 1-1/2" would fit.
Could anyone confirm the size, please? Will 1-1/2" fit to the mini's rear caliper piston?
  #93
Old 09-15-2009, 04:01 PM
WerGis's Avatar
WerGis
WerGis is offline
Short question
When you changed the front pads you used plastilube, but i can't see you mentioning here. Should i use it here too?
(on the contact surfaces and the edges of the piston)
  #94
Old 09-15-2009, 04:14 PM
OctaneGuy's Avatar
OctaneGuy
If you want to prevent any potential for squealing, then use it.
Richard
Originally Posted by WerGis
Short question
  #95
Old 09-15-2009, 04:21 PM
WerGis's Avatar
WerGis
WerGis is offline
Richard
Thanks for super-fast response btw and the best "DYI-guide" i have ever seen.
But can I use copper grease or engine grease instead of plastilube and any tips to how on earth to loosen this screw (from some reason there is a straight slot instead of a torx who I imagine will be quite the challenge)
sorry for louse pic-quality
  #96
Old 09-15-2009, 04:42 PM
OctaneGuy's Avatar
OctaneGuy
I've never seen a slotted screw instead of a torx for this. Was there a previous owner on this MINI? I'll have to defer removal of this to somebody with more experience.
Thanks for the kind words.
As for substituting the with grease..I'm not sure you want to get grease anywhere near your brake pads, but then again I've never tried...will have to wait for other opinions.
Richard
  #97
Old 09-15-2009, 04:54 PM
WerGis's Avatar
WerGis
WerGis is offline
Thank you...
Took of the other rear wheel to check and woah nothing there no screw at all, just a gaping hole and to think i've driven around with that (is that safe at all) But the screw is kind of odd the crack where you're supposed to put the screwdriver very very thin maybe i should take it to a shop to see if they had some fancy equipment to loosen it with.
  #98
Old 09-15-2009, 07:53 PM
ofioliti's Avatar
ofioliti
ofioliti is offline
Thank you...
That screw is there to just keep the brake disc in place if you remove the wheel (and during assembly). When your wheel is on, the four lug bolts hold the wheel and disc in place.
Good luck with removing that strange bolt!
  #99
Old 09-16-2009, 06:21 AM
Alex@tirerack's Avatar
Alex@tirerack
Alex@tirerack is offline
I'd hit it with PB blaster 2 days before, then again 1 day before removal. I'd use an old fashioned impact driver, the kind you hit with a hammer for removal.
Alex
  #100
Old 09-16-2009, 11:46 AM
WerGis's Avatar
WerGis
WerGis is offline
Lol i Actually managed it and it was ridicolusly easy (easier than changing bulbs on newer cars).. and it was so easy i was just waiting for something to go wrong.. and then *crack* the last 7mm Allen screw broke off inside the "brake shoe (the thing the hole shabang is secrued to that sits on the disc)".. ****...
Well now off to the store tomorrow to buy one rear right "brake shoe" and a 7mm allen screw
Other than that... this **** was so easy i was constantlig worrying i was doing something wrong
And on a last note.. the rear brake pads were so worn out that they were as smooth as glass
edit: one more thing. There are three bolts on the backside of the mounting bracket.. just wondering if all three of them are attached to the bracket or only the one on top and the one on the bottom
Quick Reply: How To Maintenance :: Changing REAR Brake Pads for Beginners!
