How To R53 Drivetrain :: Airbox Modification How-To
Old Sep 28, 2005 | 06:29 PM
  #76
lambspeed's Avatar
lambspeed
I removed the entire fire wall piece, used a larger diameter intake tube, and cut a nice big hole in the hoodimpatient:impatient Seems to work well, no problem with water, and the sound is big big big
Old Sep 28, 2005 | 07:01 PM
  #77
Soul Coughing's Avatar
Soul Coughing
i dont know how it would look, but what if you put some sort of hood over the back part of that hole. Maybe make it a ram style intake? It would be interesting to see if it helped push more air into the area around the filter; Or if it would negatively hurt the air flow coming past the filter from the radiators???
Old Mar 20, 2006 | 08:23 PM
  #78
qwertmonkey's Avatar
qwertmonkey
Could you just completly leave out the rear partition? What the point of putting it back if you have a cold air intake?
Old Mar 21, 2006 | 06:49 AM
  #79
obehave's Avatar
obehave
Here I go again.
The intake for the heater and vent system draws air in through the cowl area. Leaving this open allows heat and under hood fumes directly into the cabin area.
Old Mar 21, 2006 | 12:31 PM
  #80
qwertmonkey
Thanks!
Old Mar 21, 2006 | 06:10 PM
  #81
skuzy's Avatar
skuzy
Originally Posted by obehave
Here I go again.
lol soooooooooo 6 massive holes in the partition actually prevents this ? put
Old Mar 21, 2006 | 06:11 PM
  #82
skuzy's Avatar
skuzy
Here I go again.
lol soooooooooo 6 massive holes in the partition actually prevents this ? put another way the 6 holes only allows clean air and not heat/underhoodfumes in?
Old Mar 21, 2006 | 07:15 PM
  #83
obehave's Avatar
obehave
I've said all along that was a bad idea too.
I'm just a voice in the wilderness
Old Mar 21, 2006 | 08:35 PM
  #84
skuzy's Avatar
skuzy
im a drop in the ocean.. fyi my partition is completely off
Old Mar 22, 2006 | 05:38 AM
  #85
obehave's Avatar
obehave
You daredevil you
Old Aug 8, 2007 | 10:25 AM
  #86
Dan00Hawk's Avatar
Dan00Hawk
Here's how I modded the stock airbox using this "how to" as a guide:
https://www.northamericanmotoring.co...83#post1678283
Old Aug 13, 2008 | 05:17 AM
  #87
windman's Avatar
windman
Cone Air filter
I have looked and looked for a aftermarket air filter to sit in the oem airbox. The only one that I can find that fits is the one from mini-mania is that right? Is there not a K&N filter that will fit? I am wanting to do this mod but with out a cone filter I am not able to do it. That is right isnt? thanks for the help guys
Old Aug 13, 2008 | 06:55 AM
  #88
Kentiki's Avatar
Kentiki
I bought a Unifilter from Way Motor Works and it fits in the stock box.
Ken
Old Aug 13, 2008 | 07:48 AM
  #89
MiNi_MaC's Avatar
MiNi_MaC
Like this?
Old Aug 13, 2008 | 04:03 PM
  #90
windman's Avatar
windman
Hey mini mac
What kind of filter? Is that is that alta filter? Where did you get that filter it looks like it would work great.
Old Aug 14, 2008 | 12:15 PM
  #91
MiNi_MaC's Avatar
MiNi_MaC
^yes it is a V2 alta filter, you can buy it directly from alta, just call them
Old Dec 28, 2009 | 03:47 PM
  #92
JamesH's Avatar
JamesH
is this worthwhile on a non-S car...on other car forums people have piped this up about a drilled airbox..however lots of people have said it's bad because it disrupts the airflow...so instead of the air going directly from pipe to pipe it edies about inside the box..which is bad...so i've read
Old Mar 7, 2010 | 01:07 PM
  #93
Mike D. nucca!'s Avatar
Mike D. nucca!
At the risk of sounding lazy, do you think this could be done without removing the entire intake system? If i remove just the foam filter i feel like there might be enough room to get in there and do the drilling.
Old Mar 11, 2010 | 09:36 PM
  #94
joe_bfstplk's Avatar
joe_bfstplk
It's possible to do, but there are brake lines behind the panel that you really don't want to hit with your drill....
This guy seems to have it figured out pretty well:
https://www.northamericanmotoring.co...ml#post1678283
I'm going to pull mine out and do something like he did.
C ya,
Dutch
Old Mar 11, 2010 | 10:13 PM
  #95
Dr Obnxs's Avatar
Dr Obnxs
It's not hard to get the panel off
and then there's no risk fo messing with a hard to replace brake line. But why mess with all the little holes? Just cut a BF'in hole in the back and use weatherstrip to seal the space between the air box and the cowl panel.
Matt
Old Mar 12, 2010 | 07:23 AM
  #96
burley's Avatar
burley
Originally Posted by MiNi_MaC
Like this?
Thats brilliant, what is the filter attached to? Looks like some plumbing parts... What size and where did you buy it? I too want to ditch the Alta metal box and put the OEM airbox back on.
Thanks!
Old Mar 23, 2010 | 09:44 AM
  #97
thebigf's Avatar
thebigf
Sorry to hijack the thread but a K&N cone will work with the stock air box. Just go to the K&N website and size a universal filter. I did an RU-3130 - 4.625" big end, 3.5" small end, 7.0" long, 3.5" flange for a JCW air box.
Mine:
Old Mar 23, 2010 | 10:14 AM
  #98
thebigf's Avatar
thebigf
My favorite thing about the JCW air box - a grommet exists between the air box and the baffle but there's no matching hole.
Old Sep 25, 2011 | 10:35 PM
  #99
Yyrd's Avatar
Yyrd
reopen old thread.
why not make many small holes? as small holes will have greater area then few large holes in a confined location. spread out the airflow more evenly, might in fact look really nice.
Old Sep 26, 2011 | 03:40 PM
  #100
obehave's Avatar
obehave
Originally Posted by Yyrd
reopen old thread.
Been done.click here
Wasn't a good idea then, isn't now.
Think of a salt shaker. How big would the lid on a salt shaker have to be to flow as much salt as a shaker with the lid off altogether?
Turbulent air will stack around each small hole and lose flow proportionally greater than one large hole of equivalent circumference.
