Hawaii I need Help, PLease
Old Apr 23, 2011 | 01:23 PM
Breaker2944's Avatar
Breaker2944
Hello to everyone here. I live on Oahu,
I have a 02 Mini Cooper S.
My car died 3 weeks ago and I thought I fixed the problem. I replaced the fuel filter, and fuel pump and the car ran great for 2 weeks. Then it died again. Started troubleshooting and found I have no spark at the plugs. I do recieve gas to the injectors.
Could this just be the coil? Ive cleaned all the connections (not much rust).
Can I check the connector going into the coil? And if so, which wires am I reading and for what amount of voltage or ohms?
Can It be a relay?
Easy way to check if its the coil would be Someone out there with the same coil stop on by and switch them to see if my car starts.. just thowing that out there..
Thanks again for all replys
Old Apr 30, 2011 | 05:14 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Where do you live?
Not sure where your problem is.
If you live on the Windward side there is another MINI owner named Eddie T. who might be able to help you. PM me if you want more info.
If you live in central Oahu I have worked with an independent mechanic in the past that knows MINIs.
B & B Auto Services Center In Waipio
94-463 Ukee St # A, Waipahu, HI 96797-4465
(808) 676-2334 ‎
Ask for Leonard and tell him Brad with the MINI sent you.
He does good work and is honest.
If you live in town then another shop I have used is-
Sonic Motor Sports
1914 Republican Street, Honolulu, HI
(808) 845-1192
Seth or Robert
They have worked on many MINIs.
Old May 14, 2011 | 08:04 PM
MotorMouth's Avatar
MotorMouth
Kinda late but I'll second B&B. I've used him for other cars several times and have always been pleased.
Latka
Hawaii
61
Mar 21, 2017 10:23 PM
Nicefeet
Oct 1, 2015 05:08 PM
Clubber_Lang
Sep 23, 2015 03:43 PM
erik808
Hawaii
Nov 25, 2003 03:21 PM
The_Beastmaster
Hawaii
109
Aug 5, 2003 11:54 PM
