Widest tires on GP2 wheels?
You can make 235s fit if you want. We run a 235/40/17 and there wasn't that much rubbing on the fender liners. "That much" is obviously subjective though. A 235 isn't ideal on the narrower OEM wheel. Street tires don't take kindly to being pinched on a rim. You'll get better feel and possibly more grip by running something like a 215 that is more appropriately sized for the wheel.
What setup are you running the 235's on?
We're not all that low either. Certainly not as low as some of the other minis around here. Rubs the trailing arm in the rear rarely. Rubs the outer edge of the fender liner in the rear. Rubs outer edge of fender liner in front. Rubs inner wheel well (metal part) in front sometimes. Doesn't rub on the actual arches anywhere. Only rubbed for a little bit though then self-clearances.
The car is set up for auto-x. If I was setting it up for track I would run a touch more rear camber (-2) and lower the rear of the car a little more than we have it currently for better stability.
Sent from my DROID RAZR HD using NAMotoring
TC Kline double adjustable with 350lb springs all around. Vorshlag camber plates. -2.5 degrees of camber in the front and around -1.2 in the rear. H-sport rear control arms. NM Engineering RSe05s or whatever they're called. 17x7.5 with 5mm spacers up front. Search my posts to see some pictures of the car in action. Hard to find on my phone.
That sounds very well thought out. I was already thinking of the NM RSe05's so your insight is extremely helpful, especially since I'm planning on autocrossing. Thanks again!
Anyone running more stock-ish suspension with 235's?
Kimolaoha
Dec 5, 2020 09:32 PM
col127
Aug 21, 2015 02:11 PM
