Ouch!
Old May 31, 2015 | 09:27 AM
drlou's Avatar
drlou
Ouch!
After 100K I started hearing a bit of noise from my T.O. bearing and soon after started getting some clutch slippage under moderate load in addition to some dripping of fluid under the trans at the bellhousing/engine mating surface. Got it up in the air and drained the lube...got about 1 cup!!! When we pulled the trans this is what we found! T.O. bearing had started to come apart and the pieces were wedging between the clutch and the bellhousing wearing a hole...hence the loss of lube from the trans and slipping of the clutch. I was amazed that the clutch worked at all! Really never sounded THAT bad.
Old May 31, 2015 | 10:34 AM
velvetcows's Avatar
velvetcows
Ewww, chunks of metal in your transmission?
Old Jun 1, 2015 | 04:03 AM
drlou's Avatar
drlou
Actually chunks of metal in the bellhousing but a hole is a hole and I can't imagine some of that aluminum didn't end up on the gear side of the trans. Hopefully only fine shavings....and alum. instead of steel!
Yer Uncle
Jul 26, 2007 08:24 PM
RCristiano
23
Feb 26, 2006 07:43 PM
xxTHIR13ENxx
25
Oct 19, 2005 01:48 PM
mikem53
52
Aug 28, 2005 05:23 AM
antsmini
Off-Topic :: Autos
11
May 10, 2005 10:24 AM
