Jack Point Covers
Old Jan 13, 2010 | 06:46 PM
It Works's Avatar
It Works
Jack Point Covers
Is it really necessary to have the covers on the jack points? I lost one and was wondering if I should try to buy another one through Mini USA.
Old Jan 13, 2010 | 07:08 PM
JAB 67's Avatar
JAB 67
The jack point cover serves two purposes: (1) it has a recess into which the tool kit jack fits, and (2) it provides sufficient additional clearance so that when the MINI is taken into service the car-lifts (which are flat surfaces between the wheels) don't contact any other underbody surfaces or fixtures. So yes, most people would consider them necessary, or at least adviseable.
Old Jan 13, 2010 | 07:30 PM
ron-s mini's Avatar
ron-s mini
I would use Texas Speed Works:
http://www.txwerks.com/servlet/Categ...%3AJack+Points
Old Jan 13, 2010 | 07:33 PM
It Works's Avatar
It Works
Ok, I'm a female that doesn't know much about these things, but I believe they are just covers that don't really serve a purpose other than keeping it all clean. They are only on the GPs as far as I know (the whole underside of the GP is covered). They must be removed to jack up the Mini. Does that make sense?
Old Jan 13, 2010 | 07:35 PM
ron-s mini's Avatar
ron-s mini
Your jack fits into the covers, making lifting the car a safer.
Old Jan 13, 2010 | 07:45 PM
It Works's Avatar
It Works
This is what they look like.
Old Jan 13, 2010 | 09:41 PM
quikmni's Avatar
quikmni
The covers are probably not a big deal, especailly depending on how fast you plan to drive. The intent of the cover is just to complete the flat bottom of the GP. I suspect the minor air flow disturbance from the missing cover will never be noticeable.
That said I would procure a replace to keep the GP intact. The flat bottom panels are one of the unique things of the GP.
Old Jan 13, 2010 | 09:53 PM
It Works's Avatar
It Works
Great thanks!
Now comes the challenging part... calling the parts department and explaining what I need. They never seem to know much about the GPs...
Old Jan 14, 2010 | 04:32 AM
THE ITCH's Avatar
THE ITCH
You can go to realoem.com. When you get to the web site put in your serial # and you can navagate around and find all your part #'s.
Steve
Old Jan 14, 2010 | 07:38 AM
quikmni's Avatar
quikmni
From realoem.com, the part numbers are:
Front (Left & Right): 51777186270
Rear Right (Pass Side): 51777186271
Rear Left (Driver Side): 51777186272
Old Jan 14, 2010 | 10:40 AM
It Works's Avatar
It Works
Thanks guys! Much appreciated.
Old Jan 17, 2010 | 08:35 PM
GoodFinder's Avatar
GoodFinder
where to buy
I need to buy a replacement set for my GP, too. Where's the best place to buy MINI parts? I'm not in any hurry, and I'd rather support one of the MINI parts departments that provide discount and good service.
Old Jan 18, 2010 | 05:57 AM
THE ITCH's Avatar
THE ITCH
I have always used Classic MINI in Ohio. They are a vendor here and if you mention you a member of NAM you will recieve a discount.
Steve
Old Jan 21, 2010 | 08:35 PM
azminiman's Avatar
azminiman
Old Jan 24, 2010 | 08:39 PM
It Works's Avatar
It Works
Old Jan 24, 2010 | 08:41 PM
It Works's Avatar
It Works
Originally Posted by azminiman
Inziladun
Sep 3, 2015 10:35 AM
The_Kid
Aug 16, 2015 11:13 AM
Aug 7, 2015 05:56 AM
