Mini GP engine trouble
Old Nov 25, 2009 | 03:47 AM
jimp's Avatar
jimp
When I'm driving, suddenly the computer shuts down the power to the engine. Only allowing me to drive very slowly and not allow revs above 2.5 -3. Check engine light comes on.
I turn off the engine and restart it, and the engine returns to normal until it happens again.
Any idea whats going on?? No Mini dealership in Bloomington, IL:(
Old Nov 25, 2009 | 04:14 AM
BlimeyCabrio's Avatar
BlimeyCabrio
That's call "limp mode" - lots of things can cause it. You need to have the codes read and see if they give you any clues. Sometimes a cheapo generic code reader (like they will use for free at most auto parts stores) will give you sufficient clues. Sometimes you need the dealer scantool, or another BMW-enhanced scantool that can see the extended code and history data.
Here are some more threads:
http://www.google.com/search?rlz=1C1...anmotoring.com
Old Nov 29, 2009 | 03:29 PM
jimp's Avatar
jimp
Blimey,
Thanks for your help.
Old Nov 30, 2009 | 08:05 AM
evanbear_mini's Avatar
evanbear_mini
I have had this happen on my car before as well. My problem was that I had a missfire code. All I did was replace my coil pack, plug wires and plugs.
Old Nov 30, 2009 | 10:59 AM
quikmni's Avatar
quikmni
jimp,
Once you obtain the code, lets us know what the code is and maybe we can provide some suggestions for troubleshooting or repair without going to the dealer.
Old Nov 30, 2009 | 02:18 PM
ALTA_Jarid's Avatar
ALTA_Jarid
How many miles on your GP? Any modifications?
Old Dec 19, 2009 | 05:52 PM
jimp's Avatar
jimp
Seems it occurred whenever it was wet. Once things dried out, it stopped going into limp mode. Since I'm currently in Bloomington, IL, I'm out of luck as there is no Mini dealership. The BMW dealer wouldn't touch it.
So for now it's mystery.
Thanks again
Old Dec 24, 2009 | 01:14 PM
evanbear_mini
The next time your car goes into limp mode take it to BMW or just some mechanic place. Tell them you just want them to pull the "code". If you can get that I can help out a lot more.
09R56
Nov 16, 2022 10:49 AM
Toolman
Jan 20, 2016 06:50 AM
MiniJess
Aug 10, 2015 09:51 PM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
