Unknown sound coming from engine bay on my 06 MCS
Old Mar 7, 2007 | 11:18 AM
jclayto's Avatar
jclayto
I have a 2006 MCS with 25k miles on it. Today it started making a whiring sound. It does it when it is ideling and also when driving though it is intermittant. The closest thing I can say it sounds like is a powering steering pump that is low on oil though it is not that loud. It seems to be coming from the rear part of the engine either in the center or closer to the drivers side.
any ideas?
Old Mar 7, 2007 | 11:21 AM
sfjames2's Avatar
sfjames2
i think it might be your power steering system doing its thing. The electric motor makes that kind of a sound when it runs. start the car and see if you can duplicate the sound by just barely turning your steering wheel...as soon as you turn the wheel, you should here the motor come on.
Old Mar 7, 2007 | 11:30 AM
200-OK's Avatar
200-OK
Hard to say by your description. Do you live too far from the dealer to take it in to get checked out? It would be covered under warranty.
The only noise I had that was troublesome turned out to be a busted motor mount. Doesn't really match the noise you are describing, but it is certainly an easy thing to check for. Just search the forums and you will find more info on that if interested...
Old Mar 7, 2007 | 01:25 PM
jclayto's Avatar
jclayto
I tried what you described and heard the powersteering pump motor. The sound is exactly like that though slightly louder. It is intermittant. I dont think there are many things under there that could make this noise other then the PS pump.
Old Mar 7, 2007 | 01:29 PM
sfjames2's Avatar
sfjames2
Have you checked the fluid level?
Old Mar 7, 2007 | 07:42 PM
jclayto's Avatar
jclayto
yes it looks good. I think it might be the power steering pump cooling fan making the noise. After some research on the site here it seems to be a common problem. I am going to get the guys at Brian Harris MINI in Baton Rouge to look at it when I take it in for service in a couple of weeks.
Thanks to all that responded. I will post the results of what I find.
Old Mar 7, 2007 | 07:50 PM
MINIclo's Avatar
MINIclo
7th Gear Gal
Brian Harris MINI has a good service department. On my road trips, I have had servicing done there twice and was impressed with their attention to detail. Definitely let us know what it was.
Colt45Magnus
Jul 14, 2019 06:18 PM
chicohuahua
22
Aug 20, 2015 11:17 AM
Mini'mon
Aug 16, 2015 12:47 PM
Colt45Magnus
Aug 12, 2015 06:43 AM
