Locked Steering Wheel
Old Feb 5, 2007 | 06:10 PM
Little Peeps's Avatar
Little Peeps
Has anyone experienced their steering wheel locking. It happened to me tonight and my daughter had to play with the steering wheel to get the key to turn. It was a little unnerving. Any tips? Thanks
Old Feb 5, 2007 | 06:21 PM
Warped1966's Avatar
Warped1966
When you park, don't put the steering wheel in a bind by turning the engine off and removing the key with the wheels turned. All cars with locking steering do that. I just always turn the wheels straight and then take the key out. If it does get into a bind, turn the wheel hard in the direction that they are already turned while GENTLY trying to turn the key. Works every time!
Old Feb 5, 2007 | 07:50 PM
DixonL2's Avatar
DixonL2
That's normal if you've turned the wheels when parking, just gently turn the wheel until the lock cylinder can turn. Most modern cars have a steering wheel interlock so a thief can't "just" hotwire the car, start the engine and drive off unless they unlock the steering column too.
As noted above, try to park with the wheels in a neutral position - not necessarily straight, but kind of let off the steering wheel just before shutting down, then turn the key all the way "off". If it binds, gently turn the wheel until the key turns, and you're golden.
I thought it locked while driving - which would be a bit of a problem!
Old Feb 5, 2007 | 07:56 PM
mitchman's Avatar
mitchman
Everytime I get in our Mini, my fat butt drags across the steering wheel and it locks. But it's no big deal, you just have to turn it in one direction or the other (for me it's usually to the right), then turn the key.
Old Feb 6, 2007 | 06:03 AM
Jeremy1026's Avatar
Jeremy1026
Moderator
Mine locks all the time, alittle jiggle while turning the key and VROOM VROOM.
Old Feb 6, 2007 | 06:17 AM
BFG9000's Avatar
BFG9000
This has been a standard anti-theft feature on cars sold in the US since 1969 thanks to FMVSS 114. It has also been a requirement for all cars sold in Germany since 1962 and in the UK since 1970.
The solution has always been to try the key while turning the wheel in one direction, then the other. Sometimes you have to crank the wheel pretty hard.
Old Feb 6, 2007 | 06:48 AM
tdm156's Avatar
tdm156
Ruling the curves
I have had it happen pretty often as I usually push off of the steering wheel when I get out of the MINI.
Old Feb 6, 2007 | 06:54 PM
Little Peeps
Thanks for the advice, now I feel better.
Old Apr 18, 2010 | 07:40 PM
ytygiel's Avatar
ytygiel
Steering locks while driving - is mini a death trap?
Anyone ever seen this?
Steering wheel of 2004 Mini locks while driving. Steering wheel requires alot of force to turn. Turned the car off once and next the wheel returned to normal. Today it is hard no matter what I do.
Old Apr 18, 2010 | 08:00 PM
MLPearson79's Avatar
MLPearson79
Sounds like your power steering is going. Head to the 1st gen stock problems/issues forum - this is a pretty common problem.
Old Apr 23, 2010 | 07:03 AM
wildcrazy442000's Avatar
wildcrazy442000
I had a Volvo that had steering lock issues. Turned out the motor/transmission mounts were worn out. This caused a alignment issue with the locking mechanism.
Old Apr 25, 2010 | 12:41 PM
mrjasey's Avatar
mrjasey
if mine locks, i just wiggle the steering wheel and then the key turns just fine.
theblackfalcon
Oct 11, 2015 09:49 AM
trw92a
Aug 26, 2015 01:47 PM
nomar116
Aug 12, 2015 05:24 PM
MES11
Navigation and Audio
Aug 6, 2015 08:52 AM
