R53 Lefy key in run, won’t start…
Old Oct 24, 2024 | 08:47 AM
Blev's Avatar
Blev
I was having intermittent fuel pump issues, but when I hit it it would start and run well.
i Accidentally Left it in run with the engine off, came back and no start.
i replaced the fuel pump, Charged battery back to 100% just in case and now it cranks great, getting power to coil, but it won’t fire.
What can/should I check next?
I tried to find the fuel pressure relief valve to see if pressure at the rail, but couldn’t find it. Do I have to remove stuff or is it accessible?
i also tried testing spark at the plug end of the wire with a grounded test light, but didn’t see it light up. Maybe I was doing it wrong?
thanks!
Old Oct 31, 2024 | 03:35 AM
norhmen's Avatar
norhmen
Pressure Relief Valve: On many vehicles, the relief valve is located on the fuel rail. You should be able to access it without removing too many components. Gently press the valve with a rag to avoid spilling. If fuel comes out, this indicates that the pump is working properly and that pressure is present
swunder
Dec 31, 2012 03:21 PM
Keyser_Soze
Sep 13, 2012 08:43 PM
Jeremy1026
Mar 4, 2011 07:43 AM
waltph
Mar 2, 2011 04:27 PM
FlyingG
Jun 16, 2010 05:13 PM
