03 MCS question about 4way coolant connector
Old Feb 1, 2023 | 12:58 PM
frankiev's Avatar
frankiev
My 4 way connector started leaking and I was able to find a brass replacement . Is there any reason not to use brass rather than the stock plastic one
Old Feb 1, 2023 | 03:02 PM
Here2Go's Avatar
Here2Go
NAM Community Team
I have no experience with this connector, myself.
However, I have read quite a few contributors here on NAM highly recommend replacing/upgrading the plastic water connector(s) with OEM equivalent or aftermarket brass.
You may want to reach out to ECS Tuning. I think they may sell the brass replacement or can at least advise.
Old Feb 1, 2023 | 04:46 PM
frankiev's Avatar
frankiev
Thanks . I was concerned that the brass might react with the coolant .
Old Feb 1, 2023 | 05:53 PM
Mini Devil's Avatar
Mini Devil
I can't imagine it would. Many users run brass bleeder screws
Old Feb 1, 2023 | 06:20 PM
Here2Go's Avatar
Here2Go
NAM Community Team
Well I couldn't find the post/thread that I've seen before with mention of brass replacement other than this comment by @ECSTuning :
https://www.northamericanmotoring.co...ml#post4629079
Old Feb 2, 2023 | 06:01 AM
Yep brass will work. Whats the part number on that 4 way, been looking for that with the same Outer dimensions.
Old Feb 2, 2023 | 12:51 PM
frankiev's Avatar
frankiev
I found it on amazon . As info, I first installed it with the original clamps and it leaked so i had to use screw clamps
Amazon Amazon
Old Feb 2, 2023 | 01:00 PM
Ok so its not tight with the 3/4 size?
Old Feb 2, 2023 | 02:32 PM
frankiev's Avatar
frankiev
I measure both the original and the brass one and they were exact . I'm not sure why it leaked , maybe the old clamps stretched when I removed them . Only one hose leaked
Old Feb 3, 2023 | 07:18 AM
Ok, but the 3/4th size is the one you got?
Old Feb 3, 2023 | 08:54 AM
frankiev's Avatar
frankiev
Yes
Old Feb 4, 2023 | 05:34 AM
lastofthemohegans's Avatar
lastofthemohegans
A little food for thought; what type of clamps are we talking about here? Are they the stock spring- style clamps that need to be squeezed with channel locks to remove? If so, in my experiences, IF the clamp is not seated to fit the original silhouetted shape indented into the hose itself, coolant WILL find a path in which to leak from the hose. Worm gear clamps will not tighten down enough without causing micro tears in the hose material itself. Crimp-style ear clamps are suitable, but 9/10 times, as long as the original spring clamps are seated in their original indent, they should seal themselves just fine.
Old Feb 4, 2023 | 07:02 AM
frankiev's Avatar
frankiev
Thank you so much for that ! I didn't orient them correctly. I'm sure that's why they leaked .
Legancy
May 26, 2022 12:03 PM
Chitown_COOP
Jun 29, 2008 04:39 PM
T-Boy
Oct 1, 2007 02:52 PM
optimuspryme
Nov 20, 2006 07:35 AM
