2007 r56 cooper s timing chain tension help
Old Jan 19, 2023 | 07:48 AM
Gage666's Avatar
Gage666
Hello I have a quick question and thank anyone in advance that might be able to help you out. I was just curious on how tight the timing chain should be. Everything seems to be good and it's in time after quite a few checks however the top chain guard had to be slightly forced onto the chain in order to bolt in. I just want to know if this is normal or if the situation should be addressed before going through the trouble of reinstalling. I am not new to mechanics or anything however this is the first mini that I've rebuilt and want to cover my bases.
Old Jan 22, 2023 | 06:16 AM
garry sharp's Avatar
garry sharp
I think you can find something on youtube about this
Old Jan 23, 2023 | 03:52 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Pretty sure you’re supposed to get all the guides in place, then fit the tensioner. I would expect it to be sort of tight fit…
Old Jan 27, 2023 | 11:46 AM
https://www.northamericanmotoring.co...nsioner-2.html
This talks about the pretention.
Old Jan 27, 2023 | 03:51 PM
CakeEater's Avatar
CakeEater
The top guide is installed before there is tension on the chain, right before installing the pretensioner, before you have torqued the cam sprocket bolts.
You put in the new cassette/chain/sprocket, hand tighten new crank bolt with hub on and cam gears, put in the chain guide bolts and torque to spec, then install top chain guide and torque to spec, then install pretensioner tool. After installing the pretensioner you can torque to yield cam gears, and then torque to yield crank bolt. After that you remove the pretensioner tool and put in the real tensioner and torque to spec.
BushOner
Jul 16, 2014 02:49 PM
CLoso17
Dec 11, 2012 03:29 PM
