Results from at-home Ceramic coating
Old Sep 29, 2022 | 05:56 PM
MiniManAdam's Avatar
MiniManAdam
Community Builder
Thus is my 04 mcs that I modified my self over the past 3x years.. the paint and bodywork was done about 4x months ago and I had my buddy spray it abd I did all the befor abd after prep work.
today I used this cleaner wax and ceramic coating and not to toot my own horn but WOW , my cars brings like brand new almost ! I can't believe how well this stuff brings out the depth in the paint. Its also as hydrophobic as glass is with rainX on it.. it's awesome and sooooooo smoooooooth.
if your unfamiliar with my build here a run down of my modifications and I attached a video below showing the shine.
ENGINE :. Tpr2 big valve head. Ns1 street cam. Gen2 Sprintex supercharger with 60mm pulley and vented fill plug ( 20psi ). Snow stage 2.5 methanol kit WITH extras. 2% light weight crank. Fully ported sneedspeed Manifold. Obx 421 catless headers and nvida resonated exhaust ( passes emissions). 550cc bosche fuel injectors. Screaming demon coilpack & nology hotwires and ngk 1x step colder plugs. ported stock throttlebody throttlthrottlebody and custom 3in intake with 6in velocity stack cone filter. grs motorsport intercooler . Aluminum coolant and clutch fluid reservoirs. M7 aerogel heatshield and custom intake heatshielding. Mishimoto aluminum radiator and 180' thermostat. Detroit tuned bypass valve. Ported and shaved intercooler horn also tapped for the methanol. Upgraded silicone coolant hoses and upgraded vacuum lines. Upgraded intercooler boots. Remote activated intercooler sprayer system ( button on steering wheel). Custom tuned with tuning software and hardware and best mini tuner EVER to pass along ( 93oct , 7500rpm redline and tuned for all mods ect AND passes emissions with no check engine lights what so ever and drives great either just cruising or hauling ***). Stock clutch but upgraded singlemass flywheel. Oil catch canSUSPENSION ,STEERING & BRAKES :. drilled and slotted rotors with Ceramic pads and stainless steel flexlines and high performance dot4 brake fluid. Front adjustable control arms. Front and rear adjustable swaybar end links. Rear upper and lower adjustable control arms. Vip engine brace. Performance lower transmission mount. Polly filled or polly replaced stock bushings all throughout the vehicle. Fully adjustable hypersteet2 coilovers with fully adjustable caster camber plates. Carbonfiber Front and rear strut bars. Convertible support braces. 16x8 lightweight rims ( 16lb) , 5mm spacers and extended lugs with 205/45 firehawk indy 500 tires with under 3k miles on them. They fill out the widebody flares well. I also have the stock rims with good tires on them..INTERIOR AND EXTERIOR MODS :. full bodywork and nardo Grey paintjob. Custom rear seat delete, setup for under neath storage and hides injection pump and lines ( I still have the perfect condition stock rear seats ect ). Fiberglass widebody fenders. Carbonfiber look hood vents. Carbonfiber look side skirt/flares. Carbonfiber side mirror covers. Carbonfiber rear vents scoops for real cold air intake and brake master cooling. Carbonfiber enlarged hoodscoop and custom air diverter for it to feed through the intercooler. Carbonfiber dash. Carbonfiber downtubes. Carbonfiber overlay over many other interior parts. Carbonfiber door handle covers. Carbonfiber gascap cover. Carbonfiber adjustable spoiler. Carbonfiber exterior pillars. Carbonfiber boot lid trim. Carbonfiber look chrome delete. aero style bumper lip. Real custom 3d printed rear bumper vents ( with leds behind them). Leap rear Fiberglass diffuser. Led Unionjack turn signal markers. Led halo bumper running lights. Led halo headlights and carbonfiber trims. Led smoked sidemarkers. Led smoked foglights. Led smoked taillights and carbonfiber trims. Led color changing programable interior lighting. Snow methanol controller / boost gauge. Afr gauge and wired in wideband sensor. Multi gauge ( reads all engine parameters and reads N deletes codes ). Fully adjustable racing seats on sliders. Adjustable shift light. Coolerworx shifter kit ( best shifter EVER made ). Custom installed armrest
Old Sep 29, 2022 | 05:57 PM
MiniManAdam
Community Builder
njaremka
Mini/MINI BUILDS
92
Apr 4, 2025 05:46 AM
CHRISNYC1980
Jul 5, 2020 09:08 AM
jigster
MINIs and Minis for Sale (archive)
Oct 23, 2006 05:46 PM
