Can I use bleach under the hood?
Old Sep 15, 2022 | 11:44 AM
theateist's Avatar
theateist
I have mini cooper S 2009 R56. I haven't used it for 2 years. It has rodent droppings on the engine. I read that I have to spray with bleach on them before hosing it.
Is it safe to spray with bleach under the hood? Are there any places where I shouldn't use bleach?
(I did disconnect the battery completly from the car)
Old Sep 16, 2022 | 10:52 AM
Just use engine cleaner, i used the sonax stuff. That way its safe on the plastics and will not leave marked, I have also used on my MINI after I did the clutch and suspension work. I worry bleach might discolor certain things.
https://www.ecstuning.com/b-sonax-pa...er/543200~snx/
Old Sep 16, 2022 | 11:07 AM
theateist's Avatar
theateist
Will this engine cleaner disinfect against the rat droppings?
Old Sep 16, 2022 | 11:19 AM
Its pretty strong, my guess is it will kill anything. Good soap and water would do they same thing. Use a soft brush and watch around the electricals.
Old Sep 16, 2022 | 04:54 PM
MVPeters's Avatar
MVPeters
At least on my early car, there's no clear-coat under the hood. The first time I cleaned it with Simple Green, the paint on the strut towers washed off with ease, revealing areas of gray primer.
Old Sep 17, 2022 | 07:51 AM
jcolletteiii's Avatar
jcolletteiii
Yep, be *VERY* careful of painted surfaces under the hood. A pressure washer with no chemicals will take it off. Even pretty mild chemicals will remove it frustratingly quickly.
Old Sep 17, 2022 | 10:57 AM
BRGPA's Avatar
BRGPA
Do not use bleach in the engine bay - or anywhere it might touch a surface you value. It's corrosive and will damage metal and electrical components. Even the milder engine cleaners can sometimes screw up sensitive components, though you may need something strong for the rodent droppings. I'd wrap things that might get damaged, spray cleaner judiciously, and rinse with a gentle steam of water.
kwak1526
Oct 2, 2017 12:11 PM
kirin555
Apr 29, 2017 10:43 AM
VYPUR
Jun 26, 2011 08:39 AM
bruno787
Factory JCW Talk (2009+)
Aug 1, 2010 05:27 AM
harold47
R55 :: Clubman Talk (2008+)
Apr 16, 2008 07:19 PM
