Fault Codes
Old Jan 29, 2022 | 10:03 AM
chefjoseph's Avatar
chefjoseph
Fault Codes
I’m now getting 2 different fault codes on my 2017 Cooper hardtop which is just out of warranty. 46,000 miles:
P0171 System too lean Bank 1.
P0456 (EVAC system leak detected (very small leak)
I have determined that it is not the gas cap. It seems that I have no choice but to bring it in for service.
any suggestions?
Old Jan 29, 2022 | 12:35 PM
Here2Go's Avatar
Here2Go
NAM Community Team
Originally Posted by chefjoseph
P0171 System too lean Bank 1. P0456 (EVAC system leak detected (very small leak)
Look up Charcoal Canister or Vapor Canister.
Although I have a '04 R53. I have been getting a fault code 0456 (Tank~Venting system very minor leak detected). The SES light comes on every 4 cycles after clearing the code.
I replaced the seal on the original gas cap, replaced with a new gas cap, changed purge valve canister & various small "recirculation" fuel hoses under the hood - to no avail.
Finally determined it is most likely the charcoal canister under the right rear wheel well (on an R53), that needs replacing / is triggering the fault.
From what I have seen;The part is not cheap for later models ($300 -$450).
Check around $$ - I may be wrong.
Old Jan 29, 2022 | 02:43 PM
TVPostSound's Avatar
TVPostSound
any suggestions?
P0456
Could be the purge valve, very common here. Main symptom is also hard start after fill ups.
Old Jan 30, 2022 | 02:40 PM
chefjoseph's Avatar
chefjoseph
Yes ! The 'hard start after fill up' has happened twice. I should have mentioned that in my original post. May I ask where that valve located on the F56 3-cyl?
Old Feb 3, 2022 | 11:34 AM
Up in the front also
https://www.northamericanmotoring.co...0507-code.html
There is a bosch option now: https://www.ecstuning.com/Search/Sit...h/13907621174/
Old Feb 3, 2022 | 12:17 PM
Here2Go's Avatar
Here2Go
NAM Community Team
I hope you followed @ECSTuning link before bringing it in for service.
Your initial post had me thinking. So I checked....
In my case ( '04 R53), I discovered, I inadvertently replaced/plugged in my Fuel vent/Purge valve canister upside-down. Fixed = No more SES or P0456 tank leak fault.
The Fuel vent "valve" is in a different location (not vertical orientation) on your late model Mini. Although, I suspect that it is worth replacing at such an inexpensive cost. Check the hoses.too. It might solve your issue (?).
Lyd2007JCW
Oct 21, 2019 01:58 PM
igor2009
Off-Topic :: Autos
Jan 28, 2017 01:17 PM
RichHasty
Sep 25, 2016 05:48 PM
WS6 Formula
Oct 11, 2010 10:50 AM
NashvilleMiniStan
Mar 14, 2010 07:47 PM
