07 R56 Cooper S fuse help
Old Aug 22, 2021 | 03:24 PM
Alexzannder's Avatar
Alexzannder
Hi everyone! First post here so I apologize if it is something that has been asked/answered before. I’m currently taking apart my interior so that I can run cables for dash cam and will be tapping into the interior fuse box. Does anyone know if any of the open fuses are constant power? My dash cam has parking monitoring if I have constant power, currently fuse spots 1, 2, 6, 19, 20, 36, 41, 45
again sorry if this has been asked before and thanks in advance for any help!
Old Oct 11, 2021 | 04:25 PM
Edison Wong's Avatar
Edison Wong
Mate, have you got it done? I tapped the "constant" wire into #34, and "switch" wire to #12. It's not turning off even car is locked. Which ones did you tapped into?
Old Oct 11, 2021 | 05:44 PM
joey1320's Avatar
joey1320
Do not tap into a constant power supply. The car needs to go to sleep after 16 minutes and having constant power to an aftermarket item can cause not to, draining your battery.
You'll need to use a DVOM and find a fuse that only gets powered once the key is on (KL15) and powers off once turned off.
Good luck!
Old Nov 26, 2021 | 07:31 PM
Alexzannder
Good luck!
As my dash cam has a parking monitoring mode, I WANT constant powers, hence why I asked for it. It is hardwired in and has a voltage cutoff so that I do not drain the battery too much. I appreciate the concern and I understand the potential problems but I am not concerned with them.
Old Nov 26, 2021 | 07:34 PM
Alexzannder
I apologize for the late response, I tapped into the horn, my tap comes out, makes a 90 degree bend and has the fuse for the original slot and a separate fuse for the cameras power. I haven't had any issues with it sense install until recently where the camera isn't turning on when car is off, although that might be a camera issue or an issue with the voltage cutoff unit (I haven't checked yet). The main issue with tapping into the horn fuse is now I cannot had the cover over the fuse box so I would like to figure out a fuse at least one row in.
GLJones
Jun 13, 2024 01:04 PM
robby71
Oct 21, 2019 10:28 AM
seamonkey420
Sep 4, 2019 05:35 PM
yyj3869
Electrical
Dec 5, 2017 03:13 PM
siriuszero
Sep 17, 2015 04:41 AM
