The Jam Handle
Old Oct 1, 2019 | 02:27 PM
CravenSpeed's Avatar
CravenSpeed
Vendor
The Jam Handle
How do you close your MINI's doors? Glass? Gloss trim? Paint?! We need to have a talk about fingerprints.
You might not even realize you do it, but sure enough there's two nice fingerprints right on the edge of the door, glass, or trim when you exit your MINI.
Not the best thing to see when you look back at your MINI as you walk away.
Boom! The Jam Handle! Problem. Solved.
Backed with an automotive grade 3M adhesive, the Jam Handle simply sticks to your door jamb, just above the door latch. It gives you a dedicated spot to close the door with so you don't need to touch the paint when you shut it.
Made in the USA, this Jam Handle comes in a 2-Hole configuration that fits excellently on all MINI's. Sticking an adhesive tape to your paint sounds scary right? Fret not motoring friend, the adhesive is designed specifically for automotive use, and can be easily removed leaving zero evidence that it was ever there.
Take a look at them on our website and of course order HERE!
rphox2003
Detailing 101
Nov 10, 2017 10:55 PM
enos
May 14, 2015 06:15 AM
dj.papazian
Aug 30, 2010 04:37 AM
MINIspud
Dec 17, 2008 10:54 PM
chrisneal
Mar 1, 2005 09:59 PM
