Why is my E-Brake & DSC light stays ON
Old Jul 6, 2019 | 04:45 PM
mcs1984's Avatar
mcs1984
Hi all,
Does anybody know Why is my E-Brake & DSC light stays ON?
I had replaced the rear driver side wheel hub a few days ago, after that once I started up the car. The ebrake light stays on even I released the ebrake handle. The actual ebrakes have disengaged when I release the handle but light remains on. So as the DSC light stayed on.
At first, I thought its the ABS sensor issue because I replaced the hub. So I ordered a new one after I replaced it. Both lights still on. I have no clue what's going on with it.
I also adjust the ebrake handle level (the screw when under the handle)
Hope someone here can help.
The car runs fine, just the ebrake & DSC lights on bother me.
Old Jul 7, 2019 | 12:30 AM
Scudder44's Avatar
Scudder44
Have you read or had the error codes scanned?
Old Jul 7, 2019 | 12:56 PM
A383Wing's Avatar
A383Wing
have you checked the brake fluid level in the master cylinder?
Bryan
Old Jul 10, 2019 | 03:29 PM
mcs1984's Avatar
mcs1984
I checked the brake fluid level. It's low. I guess that the major reason. The light went off after I filled it back up to the max level.
Old Jul 10, 2019 | 03:34 PM
A383Wing's Avatar
A383Wing
Reason fluid was low is probably due to brake pads being worn.....the light is the signal to check your brakes.
Bryan
maketoast
Mar 21, 2017 12:02 PM
Rossii
Dec 31, 2011 12:07 AM
MRE7986
Jan 30, 2010 12:48 PM
Soul Coughing
Dec 23, 2005 01:18 PM
