Strangest thing that left you with a flat tire
Old Oct 20, 2016 | 08:56 AM
DaGriz's Avatar
DaGriz
When the shop replaced the run flat they found this inside the tire.
Old Oct 20, 2016 | 09:52 AM
Fly'n Brick's Avatar
Fly'n Brick
What the hell is it??
Didn't happen to me but to my motoring buddy on a road trip. One of the valve stems just broke. He had shot his tires with a real good sealant so when I tried using my pump, the sealant did its job on the leak. We motored 20 some miles to the nearest town to get it fixed with flashers flashing doing about 20 MPH all the way. Wound up replacing all four defective valve stems.
Old Oct 20, 2016 | 10:48 AM
RB-MINI's Avatar
RB-MINI
Looks like part of a spoon.
Had a key go through the tread one time. A car key was still attached to the ring.
Old Oct 20, 2016 | 11:43 AM
DaGriz's Avatar
DaGriz
Yes. It is a spoon.
Old Oct 20, 2016 | 03:05 PM
Mini Mania's Avatar
Flat Tire
Looks like some parallel universe activity!
Old Oct 20, 2016 | 03:10 PM
Squirrel724's Avatar
Squirrel724
I had the outside layer of one of my valve stems burst on me this summer. Came out from work to find a left front flat. Took me a while to find the split down the side of the valve stem.
Old Oct 20, 2016 | 04:05 PM
rkw's Avatar
rkw
This one did not actually cause a flat. It pulled out cleanly and didn't cause loss of air.
Old Oct 20, 2016 | 08:33 PM
squawSkiBum's Avatar
squawSkiBum
Moderator
Had a 10mm allen wrench go through the tread and end up inside the tire once.
Old Oct 20, 2016 | 09:19 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Does unscrewing four valve stems of a creep in college count? Not that I ever participated in such an action. I believe he had four flats that day.
Old Oct 21, 2016 | 04:26 AM
whaap's Avatar
whaap
I once saw a spark plug sticking out of the rear tire on a motorcycle.
Old Oct 29, 2016 | 05:01 PM
GeneralSpecific's Avatar
GeneralSpecific
The strangest thing that got me was...a nail. Lucky me?
I lol'd at that set of keys!
Old Oct 29, 2016 | 05:39 PM
DneprDave's Avatar
DneprDave
A ten inch piece of 1"x 1/8" steel flat bar.
It went between the wheel and the tire bead and disappeared! I didn't see it until I dismounted the tire.
Old Oct 29, 2016 | 09:21 PM
Fly'n Brick
By golly that just shook loose a memory. Years ago I had a wheel on my old TR start shaking like crazy. Finally got to a shop, pulled it off and dismounted the tire. It had a shovel full of dirt in it. I had been on a dirt road rally track, took a hard turn and must have hit a ridge hard and fast enough to let dirt in but no air out. The tire still had good pressure when they tested it.
Old Oct 30, 2016 | 03:36 PM
Eric_Rowland's Avatar
Eric_Rowland
And I thought I was the only one to have a key puncture a tire.
Old Oct 31, 2016 | 09:22 PM
GeneralSpecific
I would love to see more pictures, if anyone has them. (especially if there's keys in there)
Old Nov 8, 2016 | 09:18 PM
renchjeep's Avatar
renchjeep
Not on my MINI, but on a Police Interceptor at my work, somehow a Co2 cartridge from an air gun went right through the tread on a rear tire. Small end first. And this was not a bald tire, still had plenty of life left. Another Unit's rear tire took a 10mm wrench (which appeared to have been cut in half previously), open end first, right though the tread, and ended up entirely inside the tire. Big hole in the tread, nothing found until dis-mounting the tire. These are all W-speed rated tires, good to 186 MPH, I believe. You would think they would be a bit tougher....
Old Nov 12, 2016 | 03:28 PM
TG.'s Avatar
TG.
I guess it's a frequent thing . . . key stuck in your tires that is!!!
Almost the entire key went in.
Worse... the tire was brand new, just mounted! I must I drove about 5 miles on it but got lucky I had been offered a road hazard insurance for free on that set...
Old Nov 16, 2016 | 07:24 AM
Ace was not so helpful here.
