2012 Mini Base
Old Dec 21, 2015 | 08:08 AM
MiniTigger's Avatar
MiniTigger
2012 Mini Base
Anything special I should be looking for when going over a 2012 Mini Justa (manual 6 speed with 58k miles)?
Side question: Do the 8 spoke wheels from a Gen 1 fit on a Gen 2? Would it look stupid?
Old Dec 21, 2015 | 08:46 AM
beedeejay's Avatar
beedeejay
Mine is similar. But I have the earlier N12 engine.
I had a water pump thermostat issue at about 60K. But I think that has been pretty well resolved with your newer engine model. While they were doing that repair I had the serpentine belt and spark plugs changed.
The 2012 Justa manual should be pretty reliable. But have it checked out by a mechanic familiar with MINI’s. Brake wear, timing chain slack, shocks and struts, clutch play, tire wear, battery test. Basically the same things you should have checked out on any used car purchase.
Gen 1 uses 12mm wheel studs. Gen 2 uses 14mm studs. You would either need adapters or bore out the Gen 1 wheels for the larger studs.
Old Dec 21, 2015 | 09:03 AM
MiniTigger's Avatar
MiniTigger
Thanks for the info.
Old Dec 21, 2015 | 09:47 AM
Which 8 spoke wheels ?
Old Dec 21, 2015 | 10:14 AM
MiniTigger's Avatar
MiniTigger
These
http://www.wheelcollision.com/wccpix/59364a.JPG
Old Dec 21, 2015 | 10:37 AM
Yes , those will fit stock brakes. Unless you have The JCW factory BBK (red ). Or some other larger brake kit.
36116757859
36116773945
36116778962
R85 S-Spokes or S lites
https://www.ecstuning.com/Search/SiteSearch/R85_MINI/
Think they would work seen conical spoke ( very close in design on a R58 and looks good.
Old Dec 21, 2015 | 10:38 AM
MiniTigger's Avatar
MiniTigger
So those wheels will fit Gen 1 and Gen 2 Mini's? Same bolt pattern? Same mm studs?
Old Dec 21, 2015 | 10:44 AM
MiniTigger's Avatar
MiniTigger
Here's the one I am considering to go look at.
Gen 1 and Gen 2 MINI same bolt patter and same wheel bolt length ( Gen 2 without factory JCW BBK, unless you use ECS wheels spacers then anything will fit with the 4x100 pattern genuine MINI ).
For gen 2 not for Countryman or Paceman, they take 5x120 wheels. 5 lug.
Old Dec 21, 2015 | 10:45 AM
http://images.autotrader.com/scaler/...fc87256771.jpg
They will fit.
Old Dec 21, 2015 | 11:16 AM
MiniTigger's Avatar
MiniTigger
I would assume the rear spoiler is a bolt on mod for non S cars?
Old Dec 21, 2015 | 11:38 AM
Yes,
https://www.ecstuning.com/Search/SiteSearch/51622753758/
Old Dec 21, 2015 | 12:24 PM
MiniTigger's Avatar
MiniTigger
Do you have to drill anything out or does it attach the the hatch? Nevermind - I found it.
Old Dec 21, 2015 | 12:47 PM
ok, yea , a couple blots under the trim piece on the boot,
Old Dec 21, 2015 | 12:54 PM
MiniTigger's Avatar
MiniTigger
Oh, so you do have to drill it out. dammit. :(
Old Dec 21, 2015 | 01:10 PM
No drill , just bolts. Sorry , missed that , just a couple bolts is what I meant. When you take the rear inside hatch trim plastic off you will see what I mean
Old Dec 21, 2015 | 07:26 PM
MiniTigger's Avatar
MiniTigger
Whew! Don't scare me like that.
Old Dec 22, 2015 | 05:18 AM
Angib's Avatar
Angib
If the 8-spoke wheels are genuine Mini ones, they will work on a Gen 2 car just fine - the holes in Gen 1 wheels are big enough to take the Gen 2 wheel bolts.
Old Dec 22, 2015 | 05:46 AM
ShipM8's Avatar
ShipM8
I have a 2012 six speed with just over 60,000 miles...so very similar to the one you're looking at. At 60K the computer told mine it needed a check-up and they found that the water/coolant pump was leaking (I'd never had a problem or seen anything in my garage). That's the only problem I've had in 3.5 years, and the only thing that came up in the 60 k inspection.
Old Dec 22, 2015 | 11:14 AM
aviaator's Avatar
aviaator
Darcars huh? Fellow NoVa guy?
Old Dec 22, 2015 | 04:00 PM
isamin's Avatar
isamin
I have a 2013 JCW rear spoiler and mounting roof cap that I'll trade for a roof cap for a JUSTA (no holes) . It's midnite black in "as new" condition. PM me if you're interested.
ISAMIN
Old Dec 23, 2015 | 06:56 AM
Yes, sorry about that, typed too quick.
Old Dec 24, 2015 | 02:32 PM
MiniTigger's Avatar
MiniTigger
I'm up in Frederick (Darcars is here too) .. the car is in NoVa.
Old Dec 26, 2015 | 11:59 PM
Slave to Felines's Avatar
Slave to Felines
Oil pump solenoid leaks, thermostat problems. Those are pretty much the only real troubles on my 2012 Justa. So I recommend checking for those. The oil pump solenoid has been replaced three times so far, if I recall correctly.
Old Dec 27, 2015 | 08:42 AM
MiniTigger's Avatar
MiniTigger
