Sunroof slidders misaligned
Old Dec 15, 2015 | 03:11 PM
Dhogan265's Avatar
Dhogan265
Sunroof glass crooked
I just purchased a 28 MINI for my daughter, brought it home and started giving it a good inspection. I was cleaning and lubricating the tracks this afternoon and noticed issue, broken part on the drivers side.
Bottom line up front, I tried to close the sunroof, heard some pops, obviously a gear teeth slipping, I've wound up with the front glass panel sitting crooked and it won't move anymore. I removed the glass from the frame and can see that left and right bracket are uneven by about a inch.
At this point I'm really stuck, I just want to get the glass down and secure but I can't because the mechanism moving the glass caused the two guides to become in equal.
Is there any way to realigned this stuff? Need help
Dave
Old Dec 15, 2015 | 05:18 PM
Dhogan265's Avatar
Dhogan265
I've found some other threads that I think will be helpful, the task for the morning will be to get it closed.
I've identified one broken part, it's located in the (L) track, I can't find a detailed exploded parts diagram, not sure what it is.
Can anyone ID this thing?
This is the good one.
Old Dec 16, 2015 | 08:50 AM
hsautocrosser's Avatar
hsautocrosser
Have you tried realoem.com? It has diagrams and part numbers.
Old Dec 16, 2015 | 10:08 AM
Dhogan265's Avatar
Dhogan265
Just looked...nada, but what a great link, saving that one. I hope it's not a component of the sunroof cassette, if so I'm hosed.
I've been able to determine what it does, it's attached to a rod that raises the rear portion of the #2 sunroof.
Spent the morning messing with it, moves smoothly along the complete distance of the track but it can't close w/o grinding gears, left side slips and that cants the glass. Tried manually doing it and the gears still slip. I tore it apart enough to get my hand in there and feel if the motor is loose, it's not.
I'm hosed. I think I'm dealer bound.
Old Dec 17, 2015 | 10:35 AM
Not many single parts for the R56+ Gen 2 MINI sunroof. Just the main cassette which has the cables and mechanical slides. 54102758294 . Roller blinds and some other hardware,. Looks like the part that connects to the cable section broke. Only thing you could be is epoxy the old part, get one from a used MINI ( wrecked) , or get the new main cassette.
Parts here:
https://www.ecstuning.com/Mini-2007-...erior/Sunroof/
2008 R56 MINI Cooper
http://www.realoem.com/bmw/enUS/show...diagId=54_0372
Aug 16, 2016 01:37 PM
Countryboy22
Nov 26, 2015 07:43 AM
krawzdogg
Nov 17, 2015 09:29 AM
Nov 1, 2015 12:03 PM
Nov 1, 2015 12:02 PM
