Radiator Fluid and Oil
Old Jun 23, 2015 | 02:45 PM
Zommski's Avatar
Zommski
Hi,
I have a 2010 Mini Clubman with almost 100K...how did I get so many miles on this car?!
Anyway, I recently had my thermostat housing replaced, but it seems that my radiator fluid level still slips down below the minimum. I have three questions: Could there be another problem that is causing it to dip down below the min? Or is it just common to have to top it off every few months, especially since I do quite a bit of driving at times? What kind of radiator fluid would you recommend as I know that Mini's take a special kind?
Also, I find it hard to read my dip stick when checking my oil. Is there a trick to this?
Thanks kindly for any help you can give me. I truly appreciate it!
Have a great day,
Deb
Old Jun 23, 2015 | 04:12 PM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Are you sure there aren't any leaks in the system anywhere? Here is coolant for reference. Genuine MINI is going to be the OE coolant.
-Luccia
888.280.7799 | 6am - 5pm PST
Old Jun 23, 2015 | 04:38 PM
Helix13mini's Avatar
Helix13mini
Deb
Hold a white paper towel flat in your open hand, and lay the dipstick on it horizontally after cleaning it and then dipping it. You'll clearly see where the oil deposit is on the towel instead of having to try to read it on the stick.
HaveATank
Sep 4, 2015 08:04 AM
PelicanParts.com
Aug 25, 2015 02:46 PM
Aug 25, 2015 09:33 AM
coachvminis
Aug 25, 2015 06:58 AM
HaveATank
Aug 24, 2015 10:26 AM
