2003 Mini Cooper S Tail Light Problem
Old Aug 27, 2014 | 03:44 PM
Archduke Andrew's Avatar
Archduke Andrew
So last sunday one of my running tail lights (the lights that come on when you turn the headlights on) went out on the right side. So we took it out and examined the bulb and the bulbs were fine but the light still wouldnt come on. Then we examined the other side and everything was fine over there. After that the running lights came on for a split second then when they were put back they went out.
The next day after another examination, both running lights went out. The headlights, fog lights, turn signals, and brake lights still work, and even the fuses are all good.
What is wrong with my tail lights and how do I fix it?
Old Aug 27, 2014 | 03:49 PM
Mib4840's Avatar
Mib4840
Sounds like a short in the ground wire. After you pull the lights out again wiggle it around while it's still plugged in and on and see if it goes on and off.
SosoMINI
Nov 22, 2015 03:17 PM
joelcseymour
Aug 7, 2015 12:43 PM
Aug 5, 2015 02:11 PM
