can anybody read Kein Zugriff - Geschuetzte Fahrzeugdaten "protected information"
Old Jul 11, 2014 | 07:08 PM
bigdogrod's Avatar
bigdogrod
sorry for double post, thought there might be more action here than on the paceman side..
looking at what appears to be a used paceman s press car, bmw vin decode has these lines:
S902A
Sonderkontrolle Pressefahrzeuge Special inspection press vehicles
and
which i've read is 'protected information' is there any way to find out what this is?
thanks
rod
Old Jul 12, 2014 | 05:18 PM
TJANK's Avatar
TJANK
I assume that it is a press/media or show car released prior to wide production with many drivers testing it for articles/TVs review shows etc. I would assume it is loaded with all options available on it. I would question whether it was produced in the identical fashion or were any production changes occurred after the was produced. You did not mention mileage and whether there is any original warranty remaining. Also, you may want to check with your insurance company and if there is any change in the rate. May not be relevant but I found this article about press cars:
http://www.thetruthaboutcars.com/200...ut-press-cars/
Editorial: The Truth About Press Cars
By Bob Elton on March 24, 2009
One of the dirty little secrets of automotive journalism is that media scribes get perfect cars to drive. You might not think that from the lousy reviews some cars get, but if journalists took their chances with true production cars, the reviews would be a lot worse.
Needless to say, automakers want to show off their cars to best advantage. But somewhere along the way, the definition of “best advantage” got more than a little stretched. It’s one thing to make sure the press cars are clean and the tires aired up. But vehicle preparation has become a virtual rebuilding of press cars to make them absolutely perfect in every detail, and, in many cases, better than perfect.
In the Detroit area, there are a number of prototype shops that “build” press cars. These shops normally build complete prototype vehicles for shows and for engineering evaluation. So fixing a few flaws in a production car is nothing special. Special paint jobs, closer panel alignment, and reduced door gaps are standard operating procedure.
One car maker, annoyed by press reports of wind noise, had a shop develop a special fixture to replace the window glass. Then the car could be pressurized, and air leaks easily spotted. A rework of the body flanges, door seals and related parts fixed the leaks. No more reports of wind noise on those models! Of course, the average buyers, without the benefit of this careful massaging, took their chances.
The same company introduced a slightly revised version of their full size van a few years back. The press releases bragged about the dramatically improved build quality, and the media agreed. But none of the reporters had seen the press’ vans at the shop, where not only were they completely repainted, every visible spot weld was filled and sanded, creating a flawless surface everywhere you looked. The cargo version of the van, with no interior trim, had lots of visible spot welds. A lot of man-hours went into that bondo job but the van sure looked nice when it was done.
Another company introduced a new sedan to challenge the BMW 3 series for sporty credentials. That meant that every press car had to handle and steer very well. Unfortunately, the first fifty cars off the line were so poorly made that proper wheel alignment couldn’t be achieved, steering gears were sticky, and the tire supplier sent tires that were out of round and out of spec in other areas. The prototype shop went on red alert. The factory sent over another fifty cars, and truckloads of components.
Subframes were swapped, steering gears were disassembled and blueprinted, and the wheel alignment guys worked around the clock. Eventually the shop was reduced to welding up and redrilling mounting holes to make sure that suspension geometry was correct. This was in addition to the usual repainting, refitting and other preparations. Somehow the shop got all fifty press cars together in time, and the car got great reviews. Unfortunately for the paying customers, it took a few years for the production versions to get as good as the press cars.
Why does this situation continue?
The press needs the cars, and the companies need the press. If the press blew the whistle (assuming they even cared enough to find out about the extent of the pampering their cars get), they wouldn’t get cars to write about, putting them out of business. If the companies don’t provide perfect cars, they get savaged in the press. It’s a classic case of MAD (Mutually Assured Destruction), just like the days when the US and the USSR faced off with nuclear weapons. Neither group wants to change the rules.
The only way to get the right stuff about cars (other than reading thetruthaboutcars.com) is to listen to writers who get their cars from dealers, like everyone else.
At present, the only magazine that buys its own cars is Consumer Reports. Despite the puritanical editorial stance about fun and cars, they often have surprising insights about quality, performance, and dealer service. CR gets cars with wind noise, flawed paint, water leaks and other problems that somehow escape the notice of the buff books.
One way this could change is for the buff books to buy their own cars. But the economics of the publishing business make this prohibitive. So, since the car makers need the press, perhaps they should set up a trust fund equal to what they spend on press cars and preparation. Buff books can requisition enough money to buy a showroom example, test it, sell it when they’re done and rebate the proceeds back to the trust fund. This would also give the manufacturer invaluable insight into resale values.
Which car maker will be first to step up and make a bold commitment to objective reporting?
Old Jul 13, 2014 | 05:34 AM
bigdogrod's Avatar
bigdogrod
thanks i read the same article, very interesting read.
car is a 13, had 10k miles on it, and i asked them if they would certify it mini next, they said yes for the asking price if 26k, or let it go without next for 25.
car has every toy, nav, comfort access, is in my favorite color (blue)
carfax says it came for a bmw dealer in the puerto rico, then to new jersey for less than a year, then sold at auction and now this dealer has it, dealer says it's a former bmw exec car, but bmw vin decode has the press preparation and that protected data entry..
i think i might still get it, even if i drive it for a year and trade it in, i'd probably get my money back.. lol
Old Jul 13, 2014 | 06:13 AM
MINI_42's Avatar
MINI_42
Hello TJANK, thanks for the interesting read, I had not seen, heard or thought of any of that but it sure stands to reason. Big thumbs up to you!
Filmy
15
Jun 6, 2023 06:27 AM
///Matthew
Sep 15, 2015 03:45 AM
potterstein
Sep 13, 2015 09:57 PM
potterstein
Sep 11, 2015 09:24 PM
