Windshield washer - avoid my error
Old Apr 9, 2014 | 10:36 AM
drdave's Avatar
drdave
I recently noticed that my windshield washers stopped spraying onto the glass. After replacing everything except the reservoir and level sensor I finally tried one more thing. I drained the fluid and put in fresh fluid. That did the trick. The reason I thought of that is because I had diluted the previous gallon with water (50/50). It evidently does not work when diluted.
Old Apr 9, 2014 | 09:08 PM
RJKimbell's Avatar
RJKimbell
What Washer Fluid were you using?? I make my own...303 Windshield Washer Tablets and Distilled Water, works great and it's pretty inexpensive.
Old Apr 9, 2014 | 10:30 PM
elsenordave's Avatar
elsenordave
I mix 2 bottles of 70% isopropyl alcohol and water...
Old Apr 9, 2014 | 11:03 PM
a2oc's Avatar
a2oc
VW fluid(German ones, not the USA ones) and distilled water works for me, it cleans well even in very dilute form and it gives a nice lemon smell.
Old Apr 10, 2014 | 04:51 AM
ZippyNH's Avatar
ZippyNH
Unless it was FROZEN....should have worked fine....pump and the car DOES NOT CARE what you spray....
Old Apr 10, 2014 | 05:02 AM
ojedam64's Avatar
ojedam64
your making a correlation where one simply does not exist. its a fluid pump, and i promise it doesn't care what you actually put in the bucket.
Old Apr 10, 2014 | 07:54 AM
Fly'n Brick's Avatar
Fly'n Brick
It shows an innate ability to draw a straight line from an unwarranted assumption to a forgone conclusion. It also gave me an idea for setting up a windscreen washer system in the liquor cabinet. What a way to pump a dram of scotch with just the flick of a lever.
Old Apr 10, 2014 | 08:33 AM
ojedam64's Avatar
ojedam64
Not everyone is tech or mechanical savvy, so I wasn't passing any ill judgement.
my step father is a an awesome guy but if a light bulb goes out you better go help him or he might hurt himself.
Old Apr 10, 2014 | 09:05 AM
CA94960's Avatar
CA94960
Back in the late 1960's I met a guy that cleaned out his windshield washer reservoir and routed his washer line under the dash of his car. He would fill the reservoir with Bourbon and keep a small ice chest full of ice and a bottle of 7/UP in the car and make Bourbon/Sevens with his contraption. If he got pulled over all he had in the car was ice and 7/UP. I'm not advocating drinking and driving - just pointing out that I saw this done forty-five years ago.
Old Apr 10, 2014 | 09:16 AM
avenger's Avatar
avenger
correlation does not imply causation
Old Apr 10, 2014 | 09:18 AM
Fly'n Brick
If we can't find a little humor in everyday things then what's the point. I insist on taking satire very seriously.
Old Apr 10, 2014 | 09:24 AM
Fly'n Brick
Well dang, so the search for an original idea continues.
Old Apr 10, 2014 | 10:27 AM
ZippyNH's Avatar
ZippyNH
Ditto!!!
Old Apr 15, 2014 | 04:15 PM
drdave's Avatar
drdave
Dang. Didn't know I would get slammed for being a mechanical dork (which, by the way, I am not). I was using the standard O'Reilly's fluid that I reduced 50/50 with water. Just to rehash, I replaced EVERYTHING and it did not correct the issue until I put the same fluid back in that WASN'T diluted.
bahman
Feb 14, 2016 10:29 AM
vulkandino
Oct 31, 2015 08:29 PM
dutchhome
Sep 30, 2015 07:17 AM
ericf1993
Sep 26, 2015 03:58 PM
