Oil Filter Difficulty?
Old Jan 26, 2014 | 10:37 AM
Ballsy's Avatar
Ballsy
So after we finished a quick oil change, we went to go change the oil filter. The canister that houses the filter would not budge! Not in the slightest would it move! We had a 35 or 36 mm wrench (can't remember which) and the thing wouldn't move, even when hitting the wrench with a hammer repeatedly. We didn't have a large enough socket to use though, but how should we get this sucker off? Thanks!
Old Jan 26, 2014 | 10:45 AM
Rich.Wolfson's Avatar
Rich.Wolfson
Don’t hit it. Nothing good will come of that.
Get a 36mm socket and a long flex head ratchet. Apply even pressure and if necessary use an extension bar. It will come off.
And be sure you are turning it in the correct direction!
Not to blame the person who put it on but when you put it back, it is the o-ring that does the sealing, not the pressure of screwing it back. So, not too tight is the operative word on that. There is a torque spec, but again, not too tight will work.
///Rich
Old Jan 26, 2014 | 11:04 AM
bjcarter2's Avatar
bjcarter2
I just ordered one of these...
Lisle 14500 Oil Filter Socket : Amazon.com : Automotive Lisle 14500 Oil Filter Socket : Amazon.com : Automotive
You may find one at your local auto parts store. It is usually advertised as a Ford diesel oil filter wrench but many report it as working very well for the Mini Filter Cap. Either way, it is a low profile 36mm socket.
The torque for the cap and drain plug is a mere 18 ft/lbs. Tight is tight, too tight is broke.
Old Jan 26, 2014 | 01:58 PM
zrickety's Avatar
zrickety
Something like a 1-1/16" socket works too. It's worth buying a socket at Sears or wherever.
Old Jan 27, 2014 | 06:23 AM
cristo's Avatar
cristo
Alliance Member
1-1/16 in = 26.9875 mm, almost identical to the gen 2's 27 mm size.
The gen 1 MINIs use a 36 mm socket, however.
Use the correct 1/2" drive socket (either 36 mm for gen 1 vs. 27 or 1 -1/16 for gen 2) and a
long 1/2" drive breaker bar and some oomph and persistence. Warming and/or cooling the
engine and trying again sometimes helps also.
Old Jan 27, 2014 | 06:31 AM
buzzsaw's Avatar
buzzsaw
Read a while back that a light turn to tighten then loosen the cannister has helped.
Old Jan 27, 2014 | 07:23 PM
Rich.Wolfson
Considering the problem is that the canister bottoms out on the bottom of the base, I would say that is a bad strategy. It could do nothing but stretch the threads.
///Rich
Old Jan 27, 2014 | 07:58 PM
Ian Landesman's Avatar
Ian Landesman
The only time I had trouble doing my oil change was my first. I bought the car used. I've had it serviced at WMW and they torqued it down correctly as I had no difficulty removing it. When I had the timing chain replaced under warranty the dealership changed my oil and I am expecting to need duct tape and a long tool to get the torque needed to remove the sucker. (&$*#*
Old Jan 28, 2014 | 05:24 AM
zrickety's Avatar
zrickety
General Mini forum is confusing as the gen1 and 2 are so different.
Old Jan 28, 2014 | 06:12 AM
Gen 1 stuck oil filter housing cap. Its a 36mm socket.
Think it was here, with some tips:
https://www.northamericanmotoring.co...ng-thread.html
Old Jan 28, 2014 | 06:26 AM
Helix13mini's Avatar
Helix13mini
Once you have the correct ratchet and socket in place, really securely on the oil filter housing cap, hit the wratchet handle counter clockwise with the palm of your hand firmly. If that does not work, take a piece of pipe, jack handle or strong metal tubing and slide it over the ratchet handle making an extension for it. Extend it as high as it goes without hitting the open hood. Now do the same and you should succeed. Don't try to pull it with static force, you have to jar it with your open hand. Don't use a hammer. Don't tighten it, just jar it loose.
Old Feb 5, 2014 | 01:33 AM
babyR00F's Avatar
babyR00F
get one of those big crescent wrench and full power
Kimolaoha
Jul 5, 2023 01:04 PM
devicemanager
Jun 17, 2016 06:18 PM
Chasp
Aug 25, 2015 06:44 PM
Chasp
Aug 22, 2015 01:26 PM
Laura Redd Casler
Aug 15, 2015 09:32 PM
