Constant wobble at all speeds!!!
Old Jan 3, 2014 | 11:42 AM
DATBILLO's Avatar
DATBILLO
I have an '04 R53 and just recently today I have developed a massive wobble that gets especially overwhelming around 50mph. It has been the first snow storm of the year and my first time in my mini in snow. I hear noise coming from the front left of the dash when at 50mph and I'm not certain if its just from snow buildup in the wells or what not. Maybe I shroomed the tower from bring a little too aggressive over snow? I also noticed that there is a minor difference in space between tire and its well wall, could that be a sign of my problem?
Attached Thumbnails Constant wobble at all speeds!!!-img_7956.jpg   Constant wobble at all speeds!!!-img_7957.jpg
Old Jan 3, 2014 | 11:54 AM
Check the upper strut mounts , are the cracked really bad on that one side, causing it to be lower? Also check your suspension. I cant tell how low you are from the pics. Also make sure you knock off all the snow and ice. I guess you can have thrown off a wheel weight. Sometimes the stick on wheel weights can come off if they are hit or not installed on a clean wheel.
Old Jan 3, 2014 | 12:01 PM
DATBILLO's Avatar
DATBILLO
I have not lowered the vehicle and its pretty much bone stock. I did knock off snow. I don't know how to get to the inside of the wheel though. Just my hand and a rag maybe? But what about the break sensors.
Old Jan 3, 2014 | 12:14 PM
Small stick or sometimes the handle of an ice scraper. Your hands would be best for the wheels with a glove. The brake sensor is on the driver side near the pad and goes back to the strut (with the ABS sensor) then under the wheel well. Be careful and you will be ok. On the other side ( passenger ) the ABS sensor is right behind the rotor at the top and then near the strut and under the wheel well. Just be careful of those.
ABS sensor general location. #2
Old Jan 3, 2014 | 12:19 PM
DATBILLO's Avatar
DATBILLO
I checked my struts and they seem to be okay. Is there anything else that could be a problem?
Old Jan 3, 2014 | 12:20 PM
mattsch1981's Avatar
mattsch1981
Old Jan 3, 2014 | 12:26 PM
ashchuckton's Avatar
ashchuckton
^^^ This is your answer!
Looking at those wheels they are hugely out of balance due to snow & ice build up. Park in a warm place to melt the ice, problem gone.
Old Jan 3, 2014 | 12:37 PM
DATBILLO's Avatar
DATBILLO
Alright. I'll give the heat gun a quick use. Thanks guys. I'll report back.
Old Jan 3, 2014 | 02:05 PM
ZIPPY "S"'s Avatar
ZIPPY "S"
Your best bet is to bring it in somewhere warm.. so you can let everything melt off the car.. a heat gun idk how much that's going to do... the wobble im sure is from snow built up around the inside of the rim..this has happen to me several times..good lucK!
Old Jan 3, 2014 | 02:14 PM
gregsmini's Avatar
gregsmini
Knock all the snow and ice off the wheels and tires. The weight of the snow and ice is no different than adding wheel weights, only the snow and ice throws your wheels out of balance. I used to plow snow and when I got of snow and ice packed in the wheels, it would wobble badly.
Old Jan 3, 2014 | 02:47 PM
DATBILLO's Avatar
DATBILLO
@ashchuckton That was the problem. I cleared off all the snow and it drives like a dream once again. Thanks much. I shall panic no more.
Old Jan 3, 2014 | 02:49 PM
Ian Landesman's Avatar
Ian Landesman
When's the last time you rotated the tires? ECS's comment about wheel weights would be the first thing to check. Maybe there could be some unusual wear on the treads causing the issue? Looks like you are going to a tire shop?
Old Jan 3, 2014 | 02:59 PM
DATBILLO's Avatar
DATBILLO
The problem is fixed now. Thanks for input though.
Old Jan 4, 2014 | 02:00 PM
ashchuckton
I'm glad that worked out for you. The first time one experiences this condition it is a real oh no moment.
Old Jan 4, 2014 | 02:53 PM
jibber11's Avatar
jibber11
Exact same problem for me this morning
I got stuck in a drift in the driveway (GP is like a snow plow)
Next morning got in the highway, felt almost like I had a flat tire
Parked at the gym, an hour later car drove fine
Kinda freaked me out
Old Jan 4, 2014 | 03:51 PM
DATBILLO's Avatar
DATBILLO
It's very hard when you enjoy drifting in the snow and then start bumping around at highway speeds.
Casrio
Apr 20, 2021 01:52 AM
DevilMeTaz
R60/R61 Stock Problems/Issues
Oct 2, 2015 06:44 AM
Gremothra
Sep 9, 2015 08:42 PM
tylewis
Sep 6, 2015 01:07 PM
Ntety
Sep 2, 2015 08:39 PM
