Portable jump starters v.s Cables
Old Oct 10, 2013 | 08:37 PM
fugger's Avatar
fugger
What're your thoughts on jumper starters vs. jump cables?
I don't mind recharging it a few times out of the year but it's to my understanding that they're essentially just a battery and eventually need to be replaced a few years down the road-- rendering it completely useless. Is it correct to assume the "shelf-life" of these things are 2-3 years?
Saw a few decent ones for around $50-
$60 $60
with decent reviews. Curious to hear what you guys think
Old Oct 10, 2013 | 09:32 PM
KennyR's Avatar
KennyR
I've had a jump starter that has lasted almost 10 years, yes it needs to be recharged every 3 months or so. But I've only had to use it twice to jump one of our cars in 10 years (although it has a built in air compressor that I use more often). I've probably jumped another car with the cables (at work) much more often.
The primary advantage of a jump starter vs. cables is that you don't need a second vehicle for an emergency start. If you carry a set of cables in your car, and have a second vehicle (or another battery) in the garage, cables are probably a better and less costly option for the few times you might need it in the future.
Old Oct 11, 2013 | 04:54 AM
ACallahan's Avatar
ACallahan
Sorry to stray from the subject but couldn't help but notice you only have 18k miles on your 04 ? is it just a weekend car? I have an 04 as well but I am at 90k. As for the jumpers I have had one for prob. close to 10 yrs also and mine still seems to do the job the few times I have needed.
Old Oct 11, 2013 | 05:34 AM
insanitize's Avatar
insanitize
From: Queens, NY, spend a lot of time in Central NY
Saw a few decent ones for around $50-$60 with decent reviews. Curious to hear what you guys think
Jump starters are more convenient. Like stated in a prior post you don't need a second vehicle, also it doesn't matter where your vehicle dies (battery position) as some jumper cables require both batteries to be within 10 feet of each other.
I have gotten from 7-10 years out of the batteries (I have changed them myself) on my jump packs.
I wouldn't recommend an all-in-one (jump pack, air pump, inverter) because they take up more room and if one of the other components dies (usually the inferior air pump) then it becomes a large waste of space.
That's all I can think of now.
minimofo
Dec 26, 2015 12:03 PM
rikaro
Nov 24, 2015 02:05 PM
ahorvath
Oct 3, 2015 01:13 AM
MINI Stupor
Oct 1, 2015 11:36 AM
jennster
Sep 28, 2015 06:19 PM
