accident
Old Jul 10, 2013 | 09:38 AM
  #26
Slave to Felines's Avatar
Slave to Felines
Originally Posted by CR&PW&JB
The radiator and other parts that are on your MINI when it comes out of the factory are aftermarket.
Um, I believe that by definition any parts that were on the car when it comes out of the factory are OEM parts...
Now, saying that they are made by someone other than MINI is quite fair; many of the parts on the car are made by someone other than MINI. But that doesn't mean they are aftermarket. At a minimum, they meet MINI's specifications for fit, finish, function, and quality. Aftermarket parts might not, though they may also be of equal or better quality than the OEM parts. But it's a bit of a crapshoot.
Old Jul 10, 2013 | 12:48 PM
  #27
psichick's Avatar
psichick
The radiator and other parts that are on your MINI when it comes out of the factory are aftermarket. Not many car manufacturers make their own radiators, batteries, etc. Don't worry even a moment about that.
yeah.....no. any part that is on a car at delivery is an OEM part. while it is true that many companies use third party vendors for certain parts, they are still considered OEM and are sourced directly through the car manufacturer, not through third party vendors.
as for a body shop, as long as it's licensed by the state that's all that matters. you do not lose a warranty because of body work not done at a dealership (not that they do any body work themselves, it's usually sent out). the only time you might have an issue with warranty on a car is if there is a problem that can be traced back to the accident which was not fixed at the time of initial repair. in that case, the dealership will not cover the repair but will expect the repair shop and insurance to cover it. this would be true no matter who did the work, even the dealership. warranties are for covering issues where there is a problem from the factory, it does not and will not cover problems due to your car accident.
from the pictures it seems as if it's really just cosmetic damage, so it should be easily fixable. FYI - not sure where around the city you are located, but ray catena does deliver and i believe so does gotham mini. parts should not be that difficult to get, as there are actually quite a number of mini dealers in the area.
Old Jul 10, 2013 | 12:55 PM
  #28
CR&PW&JB's Avatar
CR&PW&JB
I'll disagree with you guys all day long. A battery in your MINI made by, let's say Everlast for example, is an aftermarket part. It's not a MINI part. If they replace your battery after delivery, you going to ask for an OEM battery ? There is no such thing.
Old Jul 10, 2013 | 01:34 PM
  #29
zigziggityzoo's Avatar
zigziggityzoo
I consider OEM to mean anything I can order from the dealer with a BMW/MINI part number.
I consider OEM equivalent to be anything that was made by the same company that made the OEM part, but purchased through alternate channels with alternate labeling.
Example: Bosch makes the battery for my BMW X3. I can order it from BMW and it'll have a BMW sticker slapped on it, or I can order it from Batteries Plus and it'll have a Duracell sticker slapped on it.
Old Jul 10, 2013 | 01:41 PM
  #30
CR&PW&JB's Avatar
CR&PW&JB
I look at it the way I do because when I went to Claim Rep school (8 years ago), they taught us that any part not made by the car manufacturer is not considered OEM. And if our estimators replace a part they mark it as an aftermarket part even it it's identical to the part they removed that was original, if it was not made by the manufacturer. But hey... won't debate anymore and hijack the thread.
Old Jul 10, 2013 | 04:47 PM
  #31
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Originally Posted by miniforceny
Thank you all for valuable advises.
Most of the parts are OEM, however, radiator and antifreeze were counted as aftermarket. I will talk to body shop to get OEM. The hood and bumper cover were marked as aftermarket or second hand. That one I am going to let go.
As per body shop, the tire, rim and all moving parts are fine. Most of the damage is body, supports, radiator and may be few hoses.
The problem now is getting all parts. There are few Mini dealers around NYC, however, not every dealer delivers.
All due respect to the body shop guys but......until that wheel is on a road force balancer to check runout, and the MINI is on an alignment lift, there is no way to "eyeball" an AOK on those moving parts. I have seen more than a few MINI's which ran up curbs creating enough of a bend in the front knuckle preventing decent alignments ect.
Have them do all that before taking delivery. It will expedite any adjustments to the original estimate and eliminate and undue delay in the process.
GL.
Old Jul 11, 2013 | 05:06 PM
  #32
condor27596's Avatar
condor27596
You gotta listen to Peanut Butter and Jelly dude! He's helpful and knows his stuff!
Old Jul 11, 2013 | 10:59 PM
  #33
noreen99's Avatar
noreen99
Glad to hear everyone is ok. Prestige MINI will ship parts to NY. Don't know if that helps but I've found them to be incredibly fast and reliable. Good luck hope it all works out.
Old Jul 12, 2013 | 04:08 PM
  #34
devicemanager's Avatar
devicemanager
Size:  96.4 KB[/QUOTE]
Is that a NY city owned car that hit you? I see a door decal and spotlight.
Old Jul 12, 2013 | 04:19 PM
  #35
miniforceny's Avatar
miniforceny
dddd
Old Jul 12, 2013 | 05:40 PM
  #36
AZdsrt's Avatar
AZdsrt
If you're lucky, they will total the mini. It will probably be reported to carfax resulting in a large hit when you go to sell it. I have my own carfax horror story..
Old Jul 12, 2013 | 05:43 PM
  #37
CR&PW&JB's Avatar
CR&PW&JB
It's clearly not totaled.
He can submit a diminished value claim to seek compensation for the loss of value.
little egg
Oct 2, 2015 11:19 PM
bahman
Sep 26, 2015 07:38 PM
Rainforest_Elf
Sep 16, 2015 10:13 AM
OdzBodkinz
Sep 11, 2015 07:20 PM
Gen1Parts
Sep 7, 2015 01:37 PM
