What does the sport button do on a Manual?
Old May 27, 2013 | 09:03 AM
EHans's Avatar
EHans
The sport button description on the Mini configurator says it does 3 things:
  1. More rapid accelleration response
  2. Tighter Steering
  3. Adjust shift points with an automatic
Now, 2 and 3 I get, and 3 isn't relevant with a manual.
What does #1 mean though? I noticed the button doesn't come on a non-S model, so does it do something to the turbo? Change timing?
Old May 27, 2013 | 09:38 AM
zigziggityzoo's Avatar
zigziggityzoo
As I understand it:
  1. Remaps throttle, so that 1/4 down on normal vs 1/4 down in sport mode opens the throttle more.
  2. allows some wheel spin, so that traction control doesn't kill your performance.
  3. Hard rev-limiter so you don't essplode the motor
  4. Some changes in the computer that I don't really understand.
Old May 27, 2013 | 09:50 AM
yetti96's Avatar
yetti96
Just as described. The throttle response is tightened up so that it feels faster. It just changed how the amount of pedal pressed is equal to the amount of throttle applied.
The steering gets heavier/tighter feeling.
Nothing to do with shift point for a manual.
Nothing to do with the limiter, timing, hp, boost, etc changes. It is all just feel...nothing more than that.
A few things change with an auto and how it shifts, but to answer you question, see my top remarks. This has been discussed a few times before and you can search and read those threads. The accusations of what that button does can get pretty wild and crazy.
Old May 27, 2013 | 10:12 AM
gasmini03's Avatar
gasmini03
The button does come on non S models, my 2013 Roadster has it.
Old May 27, 2013 | 10:22 AM
Mcameron's Avatar
Mcameron
ive noticed my coolant temps drop when im in sport mode....
during normal driving im around 210...when i press the sport button they drop to about 180
Old May 27, 2013 | 02:22 PM
EHans's Avatar
EHans
Hrm… thanks. It isn't on the configurator that I saw for the Countryman, but I could have missed it or it may be on some models, not others.
Everyone else, thanks. Seems real useful on an automatic, much less so on a manual. Interesting on the temp. Not sure what would account for that.
Old May 27, 2013 | 02:33 PM
zigziggityzoo
As a standard feature, I don't think you can choose it as an option... Should be in the specs list though.
Old May 27, 2013 | 05:17 PM
yetti96's Avatar
yetti96
The sport button is also market dependent. It used to be an option on a justa, but now in the US I believe it comes with it. In Canada it is not always standard.
Old May 27, 2013 | 05:37 PM
hsautocrosser's Avatar
hsautocrosser
The more-responsive throttle is useful in autocrossing where thousandths of a second can count and is quite entertaining on the street in a non-S.
Old May 27, 2013 | 05:50 PM
Mr. T's Avatar
Mr. T
Engage it and find out.
Old May 27, 2013 | 05:54 PM
EHans's Avatar
EHans
when I have one, I will. Probably at least 6 weeks out. For average driving though in a manual, not hearing a lot that makes it interesting. It makes a world of difference on my wife's Jetta TDI with an auto, but that is to be expected with an automatic.
Old May 27, 2013 | 06:07 PM
Mr. T's Avatar
Mr. T
Thanks for being so easy on my comment, EHans. I hope your wait goes quickly.
Old May 27, 2013 | 08:13 PM
ra2fanatic's Avatar
ra2fanatic
sitting in traffic w/o sport mode on is a nightmare. throttle response is absolutely abysmal. the MINI should have been designed so sport is always on. not having it on is such a joke...
Old May 27, 2013 | 08:31 PM
EHans's Avatar
EHans
In the manual? Granted, I only test drove it for a few miles, but it would squirt around wherever I pointed it. Most responsive car I've ever driven (well, not a Porsche Boxter, but way more fun than a Boxter!).
Old May 27, 2013 | 08:49 PM
ra2fanatic's Avatar
ra2fanatic
I'm not going to question you on that but I honestly feel its one of the moth lethargic throttle responses for a car touted to have gokart handling
Old May 27, 2013 | 08:56 PM
St_G's Avatar
St_G
Whenever I've driven go-karts, I've had to keep my foot pretty well pegged to the floor...
Sent from my Galaxy S3 using NAMotoring
Old May 28, 2013 | 04:36 AM
yetti96's Avatar
yetti96
The throttle response feels lethargic in a stick once you get used to having it on all of the time. Trying to drive with it off feels like you will stall it like a 15 year old every time you leave from a stop.
Old May 28, 2013 | 05:15 AM
kavatski's Avatar
kavatski
And vice versa - if you're used to not driving in sport mode, when you turn it on you end up peeling out from every stop because you're used to having to step on it more. Takes a little adjusting to, not that I'm speaking from personal experience or anything. The increased steering effort and throttle response are both quite noticeable.
Old May 28, 2013 | 06:34 AM
nutsofamily's Avatar
nutsofamily
If you don't have it you can code it in and enable it with moving one wire from DSC. Easy.
There is a complete write up here.
Old Sep 11, 2019 | 08:11 PM
Pmcmasters58's Avatar
Pmcmasters58
Where is the complete write up? Pls?
Have 2 minis 2010's one auto, one manual. Sport mode Auto, awesome! Sport mode manual....NOTHING.
khumpert
Nov 30, 2015 11:48 AM
theblackfalcon
Oct 11, 2015 09:49 AM
jziran
Aug 24, 2015 04:50 PM
speedbird_1
Aug 15, 2015 04:44 PM
