Living without runflat tires
Old May 15, 2013 | 07:36 PM
AustinLeo's Avatar
AustinLeo
I recently bought a used 2006 R53 which has normal, non-runflat tires. I thought I should by a small 12V compressor, some tire sealant, a plug kit, etc. But since I know a lot of you are in the same boat, I'd like to get some opinions on what I should buy. Please let me know what you carry and how well it works for you.
Thanks,
Leo
Old May 15, 2013 | 07:49 PM
4130's Avatar
4130
I've got everything you mentioned plus a tow card. I've fixed a couple of flats with the Dynaplug; worked well. I may invest in a spare for long trips soon.
Old May 15, 2013 | 07:53 PM
AustinLeo's Avatar
AustinLeo
Any suggestions on a good, small compressor?
Old May 15, 2013 | 08:04 PM
Pure87's Avatar
Pure87
I carry a can of fix-a-flat and my insurance has free roadside assistance. A tire plug kit is good to have too.
Old May 15, 2013 | 08:28 PM
OceanMini2's Avatar
OceanMini2
Fix-a-flat is not the best stuff. Slime is better. Fix-a-flat is nasty to work with when you change tires.
I have a small compressor and a spare tire in the trunk because you never know where you will be when you get a flat. (I don't have slime or fix-a-flat)
Old May 16, 2013 | 02:02 AM
w35773's Avatar
w35773
I bought an all-in-one kit with Slime and a small compressor at Wally World for $20 the day after I bought our MCS. Add a AAA+ card and I'm all set!
Old May 16, 2013 | 04:14 AM
yetti96's Avatar
yetti96
I carry a plug kit and my car has on-board air, so I skipped the cheapie cig lighter compressor for one hardwired to my battery that draws 21A.
Old May 16, 2013 | 04:18 AM
jhull413's Avatar
jhull413
Where did you get the hard wired compressor?
Old May 16, 2013 | 05:14 AM
ljmattox's Avatar
ljmattox
Slime makes a nice small one, 7x8 inches or so. At Autozone, among others. Mine was in a kit with a bottle of the sealant. I tossed in some gummy worms and an inserter. It came with a zippered bag that fits nicely in the boot held by the triangle netting.
Old May 16, 2013 | 06:38 AM
fridayxiii's Avatar
fridayxiii
Ditching the runflats was one of the first things I did for my R53, so I bought the same stuff you did as a long-distance trip kit. I also have AAA as backup. Most of my driving is urban/suburban so I don't carry this on a daily basis, but got it together for longer excursions. Can't remember what brand of compressor I have, but I bought it for ~$20 at a bike shop and have seen it at Wally World, Target, etc.
PS: congrats to OP on getting a 2006 - great choice!
Old May 16, 2013 | 07:20 AM
yetti96's Avatar
yetti96
It is a Viair 325. It was a part of a custom package I had put together from hornblasters.com I have a 4gal pancake tank in my clubman.
Here is a pic before I put the horns under the bumper.
With all of my normal car tools on top.
Old May 16, 2013 | 10:25 AM
RottVet's Avatar
RottVet
Very impressive set up you have there Yeti96! Would sure be nice to have you around when a flat occurs. I carry a small 12v compressor. I realize that Walmart and autostores sell inexpensive versions: maybe they do ok, maybe they don't. I would make a trial run at home to be sure they are up to snuff. I use the Aerostitch motorcycle models, the #3500 sells for about $50.. 6' power cord, hard wire harness, battery clamp adapter, lighter adapter and compact size carrying bag. A larger version with an 8' cord is about $100. I can attest to their robustness- takes less than 5 minutes to air up a motorcycle tire. I also prefer the slimy worm plugs with the sticky glue vs the mushroom solid plugs. Just seem to hold better for me. YMMW!
Old May 16, 2013 | 10:46 AM
gr8ful's Avatar
gr8ful
I got the spare from Detroit tuned and carrier/kit from Outmotoring.
Have not needed it yet. No Runflats for me.
Old May 16, 2013 | 10:53 AM
SpiderKnight's Avatar
SpiderKnight
I keep a can of slime in the car at all times. Also have a tow package with the insurance company.
For long distance, I roll with a donut. Got the rim at a mini dealer, purchased the tire from wheelworks or tirerack (forgot which one) and had it mounted.
Old May 16, 2013 | 12:13 PM
jhull413's Avatar
jhull413
I'm still on the OEM runflats till they wear out. After that I'm trying to figure out what I should do. The Cadillac SRX doesn't have a spare as standard equipment and doesn't come with runflats either. It instead come with a compressor/sealant combination. The sealant canister fits into the compressor which has two hoses, one for sealant and one for air. I don't know if the sealant is messy like the fix-a-flat product or more friendly like slime, though. I'm thinking about getting one of these for my MINI if I can find out more about the sealant but I don't know how much they cost. Might be pricey.
Old May 16, 2013 | 12:58 PM
got-m1ni's Avatar
got-m1ni
Same here.... I'm still on OEM run flats and I am considering ditching them and carrying a slime/compressor kit or getting a spare to carry. I don't mind the run flats though ...just don't like the costs.
Old May 17, 2013 | 02:19 PM
martinb's Avatar
martinb
Lots of info if you do some searches. Here's a copy/paste from an earlier post of mine:
I carry the following:
For tiny holes: http://www.amazon.com/Dynaplug-1007-.../dp/B000EXSER4
For larger holes: http://www.amazon.com/Stop-Go-Tubele...1520185&sr=1-3
And this (with the conventional sticky worms) as a last resort before calling AAA: http://www.amazon.com/Slime-Powerspa...520239&sr=1-13 (Only use the Slime as a last resort. It makes a huge mess.)
And you might be surprised at how small it all packs down.
Old May 17, 2013 | 02:31 PM
AustinLeo's Avatar
AustinLeo
Very nice! Thanks.
-Leo
Old May 19, 2013 | 01:35 PM
Maj's Avatar
Maj
I would avoid fix-a-flat. It rusts steel rims and eats up the clear coat on aluminum rims. Over time it creates a gooey residue which might cause balance problems and is a real pain to clean out of a tire or off a rim. Slime ain't much better, even the manufacturer recommends removing it after a couple of years because it dries out.
I recommend carrying a plug kit. Get the kind with t-handles because the tire is quite difficult to ream in order to fit the plug. A reamer with a screwdriver-style handle is almost worthless. I carry a small hand-powered drill which makes quick work of reaming a hole. A set of screwdrivers and pliers are good to have since they are handy for removing whatever it is that punctured the tire. A jack is good too since you can rotate the tire into position to make the repair and makes it a lot easier for your portable compressor to fill the tire if there is no weight on it. I successfully patched a 2-inch gash in a sidewall by inserting a row of plugs with copious amounts of glue. When I went to the tire store the next day to replace the tire the techs were blown away by all the plugs that sprouted out of the sidewall.
Has anyone actually tried to drive on a run-flat? I left the house one day and the car was pulling to the right really bad. Stinking tire pressure monitor never went off. I turned around and went back to the house to repair the tire. It had 15 lbs of air in it and was about half-flat. I can't imagine driving on that at speeds of over 25 mph.
Old May 19, 2013 | 02:43 PM
buzzsaw's Avatar
buzzsaw
www.tyreshield.com for me.
Old May 19, 2013 | 03:10 PM
Scanner's Avatar
Scanner
rear seat delete and full spare with matching wheel
Old May 19, 2013 | 03:25 PM
leedavis's Avatar
leedavis
I ride motorcycles and they use much softer compound tires than cars so punctures aren't uncommon. Sticky strings and the Slime pump make quick work of holes so that's what I carry in the Mini as well.
Old May 19, 2013 | 06:11 PM
CooperS84's Avatar
CooperS84
I bought the same compressor and slime kit.
Old May 20, 2013 | 06:21 AM
richardsperry's Avatar
richardsperry
I can't even tell you the last time I had a flat tire. (maybe 10-15 years?) I carry nothing, except the AAA card.
Then again, if I get stuck, I can afford to sit in a hotel and wait for a new tire if I had too. Hopefully I'm near Vegas or Atlantic City... Yea Baby...
Old May 20, 2013 | 08:20 AM
yetti96's Avatar
yetti96
See, that's crazy. I have plugged over a dozen tires in my driving career. (I am 27-16 = 11 years).
