overheating
Old Feb 21, 2013 | 07:50 PM
basemini78's Avatar
basemini78
overheating
Hey guys n girls! My r50 mini cooper is having an overheating problem! I replace the temp sensor and the fan relay already and that did not help. I drive the car and then let it set for about 20 minutes and the gauge will just go up and up till it hits red and flashes! Any resolutions or same problems and fixes would be appreciated! Thanks!!!!
Old Feb 21, 2013 | 08:14 PM
raffy888's Avatar
raffy888
Did u bring ur car to the dealer already? If not thet should be able to help you instead of guessing what's wrong with it.
Old Feb 21, 2013 | 08:49 PM
basemini78's Avatar
basemini78
Not yet! The thing i dont get is i had it to 2 mechanics already as well as going over it myself any nothing works. I know the fan works because i hot wired it up to see if it would run which it does. Its so strange.
Old Feb 21, 2013 | 08:58 PM
Porthos's Avatar
Porthos
Check your oil and coolant. If the oil looks like a milkshake you might have blown the head gasket.
Old Feb 22, 2013 | 12:20 AM
ZippyNH's Avatar
ZippyNH
So the fan is hotwired on....is the radiator getting hot?
Is the coolant level ok, no bubbles? If it ran low, and you added coolant, often you can get a bubble, leading to overheating. Ensure it is 100% full, and bleed it.
Next, have you inspected the waterpump for leaks...they can wearout...the vanes are plastic on some...can be an issue....and a pump worn like this, i would kinda expect the seals to be weeping also.
Is this a new issue since the thermost replacent? Maybe it was installed upsidedown? Or the before mentioned bubble from the change. And ofcourse the possible headgasket failure...can be from heat, age or corrosion...has the system been drained and refilled? Mini recommends it be done every 3 years or so...the most overlooked mantance item on a mini.
Old Feb 22, 2013 | 04:17 AM
Tex6 Hawkeye's Avatar
Tex6 Hawkeye
Older MINI, water pump and thermostat could be in need of replacement. Loss of coolant? Whatever you do don't drive it anymore, get it to the shop!
silence2-38554
Sep 28, 2015 12:19 PM
rt808
Sep 25, 2015 01:59 PM
rustof
11
Sep 25, 2015 10:35 AM
Tinklespout
16
Sep 6, 2015 11:39 AM
mimaal
Sep 4, 2015 09:09 AM
