Volume change of oil with temperature
Old Dec 23, 2012 | 07:23 AM
byron h's Avatar
byron h
I check my oil when it is cold to allow the oil to fully drain out of the oil dipstick tube so that I can clearly see the level. As the temperatures are getting colder, I have noticed a drop in my oil level. I searched the internet for the change in volume due to temperature for sythetic oil. I found the following post from the Chysler Sebring/200 Convertible Club. The change can be quite signicant and should be taken into account when checking the oil when cold.
Author: EJS [ Sat May 15, 2010 8:02 pm ]Post subject: Re: Fully Synthetic Oil, How much does it Expand ?For what's its worth----
I found these two tidbits in different places while poking around for info about thermal expansion of motor oil.
°F - °C - Density - Vol in ltrs - Vol change %
_____________________________________________
59 - 15 - 0.858 - 4.00 - 0.00
68 - 20 - 0.855 - 4.01 - 0.35
104 - 40 - 0.842 - 4.08 - 1.90
140 - 60 - 0,828 - 4.14 - 3.62
176 - 80 - 0.815 - 4.21 - 5.28
212 - 100 - 0.802 - 4.28 - 6.98
248 - 120 - 0.789 - 4.35 - 8.75
284 - 140 - 0.776 - 4.42 - 10.57
This is an example of a 5W-40 oil
0.0004 / degree F, so for a 120 degree F delta-T you get a 4.8% change in volume
Author: bigotter [ Sun May 16, 2010 8:58 am ]Post subject: Re: Fully Synthetic Oil, How much does it Expand ?There's your answer, EJS's chart proves it!! From 59 degrees F to 212 degrees F there's an increase in volume, oil goes from 4.0 L to 4.28L... that volumetric expansion should equate to the difference on your dip stick, hmmmm learn some thing new every day!!
Morris, 2011 MC, PW/B
Old Dec 23, 2012 | 07:57 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
R56 dip stick can be a PITA to read. Maybe check out the replacement one by Craven Speed so you can check oil level when hot as recomended by MINI.
Craven Speed Dip Sticks
Old Dec 23, 2012 | 08:41 AM
OceanMini2's Avatar
OceanMini2
Great info!
Kimolaoha
Jul 5, 2023 01:04 PM
TREX
Nov 2, 2019 07:31 PM
AoxoMoxoA
Aug 21, 2015 09:15 AM
elightbo
Aug 17, 2015 01:50 PM
FLYM1N1
Aug 16, 2015 01:17 PM
