Pandora?
Old Oct 2, 2012 | 06:59 PM
  #26
calforhelp's Avatar
calforhelp
Originally Posted by Eddie07S
Still, being digital you get the quality you are set at until you lose it. The settings are similar to the difference between MP3 and a CD. MP3 has a lower quality than a CD has...
This is correct. With digital the signal is either on or off, this doesn't mean it's either super high quality or nothing, it just means that something comes out of the speakers or it doesn't.
You can still broadcast a poor quality audio signal through digital by using a low bitrate and low sample rate. This essentially compresses the audio making it smaller and when this happens the music sounds like you're listening to AM radio.
Pandora gives you an option of selecting a higher bitrate stream which takes longer to download (hence you may get more stutters) but sounds better, fuller, and more true to the recording.
Old Oct 4, 2012 | 09:09 AM
  #27
08mini's Avatar
08mini
Originally Posted by Porthos
Pandora's quality is crap if you are just streaming the free version. You really need to upgrade to get good quality. I don't have an Iphone so I am not sure about the plug in feature because my Droid Razr is plugged in through the auxiliary port.
Porthos, Are you doing this with a 1/8" stereo cable from the earphone of the Droid or with the custom Y split cable that Moto sells for the car mount? I'd like to give it a try and not sure what to get. Thanks!
Old Oct 4, 2012 | 11:16 AM
  #28
JoanieB's Avatar
JoanieB
Originally Posted by dpcompt
I just tried Pandora on my '12 MCS. I have a standard radio with usb and the mfsw. The sound is similar to Sirius but other than volume, my steering wheel controls don't work. To me its just another alternate, but I wouldn't give up Sirius for it.
dpcompt, I noticed that if I started up the Pandora first, before plugging it into the Y cable, I could use the steering wheel control to skip songs. But if I started it up after plugging it in, I couldn't. Give that a try. :-) It does require the Y cable, though, not just an aux cable.
Also, I do have the paid sub for Pandora One, which allows more skips per hour.
Old Oct 4, 2012 | 11:49 AM
  #29
Gil-galad's Avatar
Gil-galad
Although I have the Pandora app, now that I have the integrated MOG in MINI Connected I hardly ever use it. I guess that's partially a function of feeling like I need to exploit the fruits of the monthly MOG fee as much as I can. I didn't renew the complementary 1-yr Sirius subscription. In retrospect, for my own use habits I think paying for Sirius instead of MOG (along with the available Pandora, Stitcher, and the MINI Connected Internet radio) would be a better bet.
Using the iPhone-supplied USB cable only I get full functionality and album art with both MOG and Pandora. I've never had to rely on the Y-cable for anything.
kyungmanpark
Aug 23, 2015 07:26 PM
biggripper
Mar 23, 2011 05:19 AM
arisoup
Mar 13, 2011 09:24 PM
PostRelease
Jun 1, 2010 10:01 AM
PostRelease
