AC Clutch bearing
Old Sep 4, 2012 | 06:21 AM
targabill's Avatar
targabill
AC Clutch bearing
Hi Mini experts... I've been searching but no luck finding info..
Looking for a part number, or dimensions for the BEARING in the AC compressor clutch...
I have 2003 copper S
These are not very difficult to change and much cheaper then buying a compressor...
thanks Much..
Old Sep 4, 2012 | 06:33 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
a/c clutch
Never seen it any place else and I afford no credibility to this part's application or effectiveness.... started seeing this ad about 6 months ago.
Old Sep 4, 2012 | 06:45 AM
targabill's Avatar
targabill
Thank you for replying, But I'm looking for the BEARING in the clutch, not the Coil.
Anybody else know::
Love this forum...
Old Sep 4, 2012 | 07:17 AM
Porthos's Avatar
Porthos
This is what realoem has. They probably don't sell the bearing separately.
Old Sep 4, 2012 | 07:38 AM
targabill's Avatar
targabill
The part number and/or bearing dimensions are usually printed right on the bearing. Then there are dozens of site like http://bearingsdirect.com/ that sell these. Just seeing if somebody pulled there's and has this info. Hoping to have the new bearing in my hand before pulling the compressor.. Don't want to cooper out of commission too long
thanks
Old Sep 12, 2012 | 06:14 AM
targabill's Avatar
targabill
Hmm, nobody ever popped out the bearing from the air condition compressor clutch assembly?? Was hoping to get the dimensions, so I can buy the bearing before pulling it apart.....
Old Jun 2, 2014 | 05:44 PM
gtmotor's Avatar
gtmotor
targabill, did you ever find what you were looking for? My bearing needs to be replaced and if you have any information that could help I'd appreciate it.
Old Jun 12, 2014 | 09:17 PM
gtmotor's Avatar
gtmotor
If anyone else digs this up, here is the info on the bearing:
Nachi 35BG05S7DL
  • Category: Ball Bearing
  • Inner Diameter: 35 mm
  • Weight: 0,153 kg
  • Quality: High quality
  • Outer Diameter: 50 mm
  • Brand: NACHI
  • Thickness: 20 mm
http://www.123roulement.com/roulemen...7DL-NACHI.html
Old Aug 17, 2022 | 08:15 AM
miniguymini's Avatar
miniguymini
Nachi 35BG05S7DL
      • Weight: 0,153 kg
  • Brand: NACHI
    • Thickness: 20 mm
thanks for this. Dug this up after 8 years.
is it the same for an r56 2010 mini?
QuickCooper
Jan 26, 2018 01:21 PM
QuickCooper
Dec 29, 2016 06:46 PM
Sep 23, 2015 12:59 PM
Sep 22, 2015 02:05 PM
Sep 3, 2015 02:06 PM
