How do you lubricate the sun roof?
Old Jun 4, 2012 | 10:59 AM
t-bear's Avatar
t-bear
There are plenty of threads talking about what to use but I have not seen any on where to lube!
I cleaned the rails and put lube inside the tracks on the sides, but it was worse than when I started.
So I put some lube on the top of the rail thinking the part may touch when sliding, nope did not help.
I then found that the metal part that slides on the rail touches the side of the rubber seal on the outside of the sunroof while it is moving and I put some silicone grease there and that helped a lot.
So where am I supposed to be lubricating?
Old Sep 3, 2012 | 08:30 PM
gmeerkreebs's Avatar
gmeerkreebs
need the same info! any luck finding out where/how to lube???
Old Sep 4, 2012 | 06:29 AM
slinger688's Avatar
slinger688
I use dry lube which does not attract lots of globbing dirt and dust. Do the rails and any moving parts.
I also use the wet Silicon or Teflon on the rubber but I rub off the excess to leave a thin film only.
Old Sep 4, 2012 | 06:41 AM
buzzsaw's Avatar
buzzsaw
I use a dry or grease free liquid lube. I then use a soda straw(bendy type) and place it down the track with the roof open and give it a shot with the little red nozzle attached to the spray nozzle. I do this every 60 to 90 days and sofar so good.
Old Sep 5, 2012 | 08:34 AM
t-bear's Avatar
t-bear
What I have found it the biggest issue is the rubber on the sides of the sunroof.
I put some Silicone on a rag and wipe them down every month or so and the issue is no more!!!
Lex2008
How to
47
Jun 15, 2022 06:18 AM
1chaos52
Sep 21, 2015 05:42 AM
///Matthew
Sep 15, 2015 03:45 AM
KristaMcCoy
Sep 12, 2015 05:37 PM
Accessory Products
Sep 10, 2015 11:38 AM
