Replacing Hub Assemblies
Old May 23, 2012 | 08:46 AM
ThomB's Avatar
ThomB
This is not a post asking "how to" or "how do I" rather a public service announcement for anyone that decides to undertake replacing the bearings them self. (it's actually quite easy)
The Story:
I recently purchased new hub bearing assemblies for my car. (I have a 2005 Cooper Cabrio). I was careful to look everything up on the vendors site (through eBay) to ensure what I bought was correct. I received the rear hub and installed it in almost no time; it went on great fit perfect looked good!!!
Then..
I tried to mount the tire and that's when I realized my lug bolts would not fit. You see I had the older (smaller 12mm) lug bolts and the hub I purchased was for the newer (larger 14mm) hub bolts. I don't blame the vendor for not knowing (I called and spoke to him) this and it was not something I thought about when buying.
I was able to get new lug bolts from the dealer, but I think a good thing to remember is that you may want to ensure that you order the correct size hub assembly to use you existing bolts or as I did get new bolts that are the correct size.
For reference I paid $65 for the rear assembly. The assembly I received is Timken # HA590161 (the vendor referenced them as NT512304)
The fronts were about $89 each and aren't here yet so I don't know what size bolts (EDIT - They will use the older 12mm bolts) I'm going to need. I should be able to update if anyone cares to know where I got the stuff.
Last edited by ThomB; May 23, 2012 at 10:45 AM. Reason: They will use the older 12mm bolts
Old May 23, 2012 | 11:05 AM
Porthos's Avatar
Porthos
Why did you change your bearings? Were you having the bearing failing noises?
Old May 23, 2012 | 11:12 AM
ThomB's Avatar
ThomB
Yes. mostly the reason.
I recently installed new Shocks / Struts / Tie-rods / etc. and still had some issues (noise in the right front) so since my car spent 6 years in the rust belt of Northeast Ohio (and I'm now in NC) I decided to just replace them all to attempt to combat the salt/rust that is taking over. I had to drill out a rotor retaining bolt on one of them and never repaired it the right way so this fixed that too.
Old May 23, 2012 | 12:24 PM
Porthos's Avatar
Porthos
Don't forget you do have a rust warranty through MINI so if the body starts rusting take it in.
woodstudio
Mar 15, 2020 08:28 AM
Rai1gun
R60/R61 Stock Problems/Issues
Jan 11, 2016 05:52 AM
Aug 7, 2015 09:51 AM
