What's so good about Mini's?
Old Dec 17, 2011 | 02:35 PM
  #101
nodoze's Avatar
nodoze
Originally Posted by Eddie07S
nodoze...you don't list a LSD in your signature. With the power your Mini has, that would make a big difference.
The compact size and not having a rear axial means that the Mini has a low polar moment of inertia which means they change direction with minimal input - they are tossable...to me that means fun
An LSD is a non-trivial amount of money, and definitely not worth pursuing if you don't also need to replace the clutch. If I still have the car when the clutch goes I'll consider it, but for the money I'd rather get a set of coilovers I think
Old Dec 17, 2011 | 02:46 PM
  #102
Eddie07S's Avatar
Eddie07S
Absolutely...not cheap. It was a great option before Mini dropped it. I wish I could have gotten it on my '12.
Coilovers are a great option too, but good ones cost too. An in between option would be a set of springs. A little lowering and a little stiffer does the car good. Some people say the ride improves with a spring change (not sure I understand that with constant rate springs, but that is what some people say). Do some research on here; there is a lot of good information to be had about these mods.
Old Dec 17, 2011 | 03:51 PM
  #103
new2minicoop's Avatar
new2minicoop
Uhh. LSD? Coilovers?
are we talking about drugs?
Old Dec 17, 2011 | 03:58 PM
  #104
DneprDave's Avatar
DneprDave
LSD - Limited Slip Differential
Yeah, I don't like jargon and vague acronyms either, but what are ya gonna do?!
Coilovers - Coil over strut.
The shocks and springs are assembled as a unit and the springs must also be replaced when the shock wears out.
Dave
Old Dec 17, 2011 | 05:57 PM
  #105
nodoze's Avatar
nodoze
I have looked into both, but the cost of new springs and struts is close enough to a coilover set that it isn't a huge deal. It's also more important to fix the suspension first than getting fancy and putting an LSD in
Old Dec 17, 2011 | 06:09 PM
  #106
Eddie07S's Avatar
Eddie07S
Dave
Oooops...sorry 'bout the jargon.
and getting off topic...but then again, that is one of the things to like about Minis is to mod them. There is something for everyone; change the looks, handling, perfomance, sound, etc.
Old Dec 17, 2011 | 06:13 PM
  #107
Eddie07S's Avatar
Eddie07S
With either route, look into camber plates. The fixed plate from Ireland Engineering is a modest price mod that is one of the best changes you can make next to the RSB (rear sway bar). Worth doing if you are doing springs or coilovers.
Old Dec 17, 2011 | 07:39 PM
  #108
danigurrl's Avatar
danigurrl
WTF? You're telling me my $30k car doesn't even have LSD? I thought I read that 2012 do come with it.
So my econobox Saturn had LSD...my brand new 'motoring' car doesn't? This winter is going to suck. :(
Old Dec 17, 2011 | 07:52 PM
  #109
mrluckypa's Avatar
mrluckypa
LSD is obsolete . most vehicles today have traction control. If I am not mistaken your MINI has traction control
Old Dec 17, 2011 | 07:56 PM
  #110
nodoze's Avatar
nodoze
All minis have them, I don't think you can buy one without it. Obviously you can turn it off, but I don't recall being able to buy it without it
Old Dec 17, 2011 | 08:04 PM
  #111
Blainestang's Avatar
Blainestang
You have the Sport Package, and DTC is part of that package. Having DTC means you have an electronic LSD... just like many BMWs, Porsches, etc.
Old Dec 17, 2011 | 08:06 PM
  #112
danigurrl's Avatar
danigurrl
Not the same.
Old Dec 17, 2011 | 08:07 PM
  #113
walk0080's Avatar
walk0080
You are thinking traction control and stability control. Both very useful, but neither are the same as mechanical or electronic limited slip differentials. MINI used to offer a mechanical LSD then later offer an electronic version called DTC.
I remember reading in the manual and it seems by default the DTC is NOT enabled (if equipred) unless you partially disable the stability control, like for a track event. I haven't had time to check or try it out but it's on my list to do with my JCW. If you happen to live in Canada, it appears you only get DTC with the JCW.
Old Dec 17, 2011 | 08:45 PM
  #114
Blainestang
True, the eLSD is not "ON" until you press the DTC button. This "loosens" the parameters for the stability control kicking in and turns on the eLSD.
If you hold down the DTC button for a few seconds, it turns off all traction/stability control and leaves only the eLSD.
According to MINI, pressing the DTC button is beneficial in snow because it allows some 'slippage' before cutting power to the wheels, etc.
One notable advantage of the DTC over a "traditional" mechanical LSD is that most mechanical LSDs can only transfer a percentage of power away from the spinning wheel. In the case of MINIs now-unavailable LSD, it could transfer just 30% of engine power to the wheel with traction. The eLSD, however, can transfer as much as 100% of the power to the wheel that has traction.
DTC only comes STANDARD on the JCW, but from a quick look at MINI.ca, it's optional on other non-JCWs. The same goes for the US. DTC has been standard on JCWs since the release of the Factory JCW in '08 (Model Year 2009), but DTC wasn't available on the Cooper or Cooper S until December '08 builds.
Old Dec 17, 2011 | 09:05 PM
  #115
walk0080's Avatar
walk0080
That's good - when I put a deposit down this past summer, there was no mention about DTC/EDLC on non-JCWs in Canada for 2012. It seemed odd as it is really just a software feature that should not be limited to JCWs. I look forward to trying it out.
Old Dec 17, 2011 | 09:09 PM
  #116
Blainestang
Exactly... It's purely software, IIRC. Mechanically, it just uses the sensors and mechanisms from the other existing systems (ASC, DSC, ABS, etc), which is probably why it costs only $250, now.
Old Dec 18, 2011 | 04:07 AM
  #117
new2minicoop
Guys, you're getting totally off topic of this thread! This thread is to post why you love your Mini and why you think Mini's are great. Too much mechanic talk going on!
but, having tried to read the past 10 posts, and as a last post before the tech talk ends, what's the purpose of an LSD, and does my 2012 have one, and will I be screwed this winter without one?
Old Dec 18, 2011 | 04:36 AM
  #118
JenK's Avatar
JenK
Originally Posted by Slave to Felines
BMW has brought at least one diesel over here. A co-worker has one, and I have seen a bunch of ads for them. I'm betting that they're using that as a test program and that we'll see more oil-burners if it sells well.
...And that will, at least for them, answer the question about Americans buying diesels or not...
I currently drive an X5 diesel and it is awesome. But, the MINI I want to get is 'awesome-r'!!! The x5 diesel sells well and the 335d sells well with the eco-credit incentive. I got 3500 off the top immediately last year and eventually got about 10k off MSRP. If no incentive, I would not have bought it! I have some reservations about the diesel at first, but the truck is a great ride with plenty of power and really good gas mileage. I would hope BMW would offer all the diesels they make over here including MINI!
To the OP, sorry to further hijack this thread! from reading you recent posts, you and your car are starting to bond! Now, you need to name it!!!
Old Dec 18, 2011 | 04:41 AM
  #119
JenK's Avatar
JenK
I truly think MINI's are great and I don't even own one yet! I've been lucky enough to test drive and have one as a loaner while my X5 was being serviced. I just need about 6 more months to get out of being upside down in the X and I'll be ordering my new Clubman S!
LSD stands for limited slip differential and I am not sure if your car has it, but I really don't think you will have problems this winter without it. I am sure others will chime in here about this.
Old Dec 18, 2011 | 04:45 AM
  #120
Astroclub's Avatar
Astroclub
From an advertisment
Because all-wheel drive is for wusses, you need a 2012 Mini Cooper. Making the most of FWD with light weight and electronics, the Coop offers an unbeatable fun factor guaranteed to brighten up an otherwise dreary day. Automatic Stability Control + Traction helps prevent wheel spin for lots of traction on start-up. Cornering Brake Control and Electronic Brake force Distribution manage braking balance between the front and rear axles, and Brake Assist enables maximum braking pressure to minimize braking distance. Standard Dynamic Stability Control intervenes in engine management when necessary and applies brake force to individual wheels (it also includes hill assist). Optional bi-xenon adaptable headlights, fast airbags, and a rigid chassis — who says bigger is better when it comes to winter driving?
Old Dec 18, 2011 | 05:36 AM
  #121
Eddie07S's Avatar
Eddie07S
You two are not the first to ask about Minis in the snow. There are many thread covering this subject and how great they are. There are even pictures posted of people in snow so deep they are plowing it.
My personal experience is from having run 2 Minis in Upstate NY since 2003 through the winters that we have and have no problems. The '04 that we have doesn't even have traction control and we run all season tires on all the cars. The '07 (with traction control, no LSD) has taken me skiing to places like Gore, Whiteface, Stowe and Jay Peak. I have driven home in 3-4" of salted mush at least once - with all season tires.
Here is another thing to love about Minis...they are great in the snow.
I am, however, looking forward to a new set of snow tires and the DTS on my new 2012.
BTW - I believe that the eLSD is on all of the time with DTC. Just checked my manual. There are 2 "off" settings. The first is to turn off the traction control. This allows you to spin the tires. There are occasions where this may be neccessary to do, like rocking the car if it is stuck in 11" of snow in a parking lot (been there). The second off setting turns off the both traction and dynamic stability control. It is likely that the only place that you might want to do this is on the track (race course) or autocross. In all cases the eLSD is on. The manual states "Intervensions (differenctial lock) in braking occure to improve propulsion when drive wheels are rotating unevenly, even when DSC is deactivated.".
Old Dec 18, 2011 | 03:57 PM
  #122
Btwyx's Avatar
Btwyx
With a regular differential, if one wheel spins it gets all the power from the engine. The wheel which actually has grip will get no power. With a limited slip diff, the wheel which still has grip will get some of the power even if the other wheel is still slipping. As stated above, with the old mechanical lSD (available on Ss up to 2009 I think), the non slipping wheel can get 30% of the engine power while the other wheel is slipping.
This can be useful in "spirited" driving, for me it only comes into play on the track. Ideally you want to get on the power as soon as you can while cornering, but while cornering the inside wheel is lightly loaded, so will tend to slip easily. With an LSD you can get more on the power earlier than with a traditional diff. Our Cooper-S has the mechanical LSD, I can get on the throttle early and still get power out of the corner. Our Cooper doesn't have an LSD and at the last track day got a distinct smell of burning rubber when I got on the power too early after turning off the DSC (and thus traction control).
I assume driving in snow has similar problems, but its not something I'm familiar with. Your 2012 doesn't have a mechanical LSD, they havn't fitted those since 2009, if you have the DTC option you'll have an electronic LSD. (Where the brake is applied to the wheel that slips to divert power to the other wheel.)
Old Dec 18, 2011 | 07:34 PM
  #123
Blainestang
It's kind-of hard to say when eLSD is 'completely off' because in ANY mode, the car may apply the brakes to a spinning wheel.
That said, the difference between eLSD and the way it reacts to a spinning wheel is that it EXCLUSIVELY uses braking and will not cut engine power.
So, when in the "all on" mode (no buttons pressed), the car is going to use all means necessary (cut power and/or brake) to make sure that the wheels are not spinning faster than necessary for the given speed.
That means that if your tires NEED to spin some to get going and/or continue moving, as in low traction circumstances, you might not be going anywhere. That's the purpose of turning off systems or turning on the DTC.
Without intimate knowledge of the programming of the systems, there's no way we can say for sure how it all works, but my point is that the purpose of DTC / eLSD is that it transfers power to the wheel with more traction BUT allows some spinning/yaw/etc. So, if you leave all the systems on, meaning you want ZERO slippage or differential rotation rates, you're essentially defeating the purpose of the DTC / eLSD.
OK... here's why I love my MINI:
I went to a Porsche vs. BMW Auto-X event last week, and despite being totally stock, having crappy All-Season tires, and having just 118hp, I had the fastest time amongst the MINIs and a faster time than 10+ Porsches and numerous BMWs.
It has to be at least a little disappointing to lose to a 118hp MINI Cooper with All-Season tires when you're driving a Porsche Boxter, Cayman, or 911.
Old Dec 18, 2011 | 07:41 PM
  #124
dannyhavok's Avatar
dannyhavok
Blainestang, nice video. That looks like a lot of fun... way to represent the Justa
Old Dec 18, 2011 | 07:55 PM
  #125
Blainestang
It's a blast! Absolutely a must-do for anyone with a MINI, IMO. This type of performance is really what sets the MINI apart from it's competitors. That and it's uniqueness/character.
