Removing Rear Seats
Old Oct 14, 2011 | 06:32 AM
Marwan's Avatar
Marwan
Removing Rear Seats
Hello guys,
Any one knows how to remove the back rest for rear seats? Im installing a rear seat delete kit.
Thanks!
Old Oct 14, 2011 | 06:59 AM
CRoth's Avatar
CRoth
Once you've taken the torx bolts out of the middle support you will have some room to move the seats. This movement will allow you to get the sides out. The seats have a metal dowel with a pin through the end horizontally that that needs to be lined up with a slot to be removed. If I remember correctly, the seat needs to be at a 45 degree angle to have the pin lined up correctly. You can just apply pressure by pulling slightly away from the side while lifting the seat from flat to upright. You will feel it pop out once the pin is aligned correctly with the slot in the hole.
Old Oct 14, 2011 | 08:45 AM
Marwan's Avatar
Marwan
Thanks man. I was not able to do it. Which seat should be at 45 angle? Should the oyher be folded or in normal position?
Old Oct 14, 2011 | 09:11 AM
CRoth's Avatar
CRoth
Start with them both folded down and work one side at a time. It doesn't matter which one first. Make sure both center bolts are removed before you try this. You need to have some play to work the sides out. Once the first side is out the other will be easy for you.
Old Oct 14, 2011 | 09:32 AM
CRoth's Avatar
CRoth
Here;
http://www.mini2.com/forum/faq.php?f...aq_faq_removal
This is more detailed.
Old Oct 14, 2011 | 10:04 AM
Marwan's Avatar
Marwan
Thanks a lot bro.
Old Oct 14, 2011 | 10:29 AM
CRoth's Avatar
CRoth
No problem
Old Oct 14, 2011 | 10:43 AM
MiamiGuitarMan's Avatar
MiamiGuitarMan
not to get too far off topic but what is a rear seat delete kit? And do they make one for an R57 cabrio? I haven't used my rear seats since I've had the car and I'd love to take them out and have the space free for carrying stuff.
Old Oct 14, 2011 | 12:24 PM
CRoth's Avatar
CRoth
You're actually not off topic at all and it does exactly what you want. The only problem is that I've never heard of any RSD kits for a cabrio. I just Googled it and found threads on people wanting them but having to fab their own due to lack of demand, I guess. Try Outmotoring, they would know.
Old Oct 17, 2011 | 02:52 PM
Eriamjh's Avatar
Eriamjh
I would love to put a rear seat delete kit in my Clubman! what are they?
Old Oct 17, 2011 | 02:56 PM
CRoth's Avatar
CRoth
http://www.outmotoring.com/mini-coop...elete_kit.html
Old Oct 17, 2011 | 02:57 PM
CRoth's Avatar
CRoth
I don't know if they make them for clubbys or not.
flyers47
Jul 27, 2020 02:38 PM
mishanja
Jun 22, 2016 09:59 AM
Mini'mon
Aug 26, 2015 01:02 PM
mini4thewini
Aug 19, 2015 05:18 PM
