Throttle Response is Terrible on these cars
Old Aug 2, 2011 | 04:24 AM
  #26
slinger688's Avatar
slinger688
I reread the OPs question and it is specifically about heel-toe down shift slowness that has to do with the heavy dual OEM mass flywheel.
OP, I still heel - toe almost every downshift and with stock flywheel, the only thing you can do is use the wait time to down shift slower and use neutral as a check of which gear you are moving into.
Old Aug 2, 2011 | 05:50 AM
  #27
adr3naline fix's Avatar
adr3naline fix
Originally Posted by Porthos
I would have to be in the car with you becuase this seems to subjective to really deem a throttle response isse. I have never had a problem with my car and drive by wire. Acctually both of the cars that I had that were drive by wire were just as resonsive as my cars that were cabled. Though at least with a cable driven car you could always tighten the cable and get a little more response out of it that you can't do with the new system.
It's absolutely subjective to your taste. And my taste is that this car is terrible for a "driver's car"!
Old Aug 2, 2011 | 07:25 AM
  #28
Porthos's Avatar
Porthos
Its not that big of a deal. I am just saying I would have to ride in your MINI to see what you are talking about.
Old Aug 2, 2011 | 09:43 AM
  #29
mlymanz71's Avatar
mlymanz71
I use mine as a daily driver and I know that the lag is there on my R53 but just adjusting my clutch/shift patterns has made a huge difference in the way it responds. I am actually currently looking into some options that have been used on other applications to make the lag a little less of an issue. If I am able to locate a suitable option to fix it (cost effective) I will post it up.
Old Aug 2, 2011 | 12:39 PM
  #30
martinb's Avatar
martinb
Curious. I have an 06 cabriolet with every JCW option and the throttle response is brisk and immediate.
Old Aug 2, 2011 | 06:01 PM
  #31
ZippyNH's Avatar
ZippyNH
Just proves that every gen1 mini is a bit different!!!
One reminder to some readers...gen1 MINI's (like the op's) do not have a sport button...it is ALWAYS SPORTY!!!
VYPUR
Nov 21, 2023 08:04 AM
xpunisherx
Aug 10, 2015 10:50 PM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
bctf1
Aug 6, 2015 12:55 PM
