100 or 110 octane on MCS.
Old Apr 6, 2011 | 06:41 PM
lshsoul's Avatar
lshsoul
I put Shell's V-POWER(octane rate 93) on my 2011 MCS.
Few days ago, I found 100 unleaded octane gas at citgo
Although I pumped 93 as usual, I wanna try it, but worrying it could harm
my MCS. Is it ok to pump 100? I know high octane gas does not work on
regular cars, but I think out MC or MCS are different.(What I mean MINI
requires premium gas) If I put 100 or 110, will i get a better mileage or better
performance?
Thank you.
Old Apr 6, 2011 | 06:59 PM
Evasive's Avatar
Evasive
Unless you're tuned for higher octane, the only performance you'll gain is in power to weight ratio. Less money in your pocket = less weight.
Seriously though...no reason to go higher octane. You should be able to run 91.
Old Apr 6, 2011 | 08:43 PM
Gizmo's Avatar
Gizmo
100 octane and 100LL...hmmm...now you are going into the world of AvGas.
In a MCS there is no major improvement that would out weigh the cost. Just stick with the normal premium and you will be fine.
100 octane is rated for a higher compression ratio, a ratio that a regular non-tuned MCS engine cannot reach on its own.
The last time I flew, the price of fuel per gallon was $5.60, save the money, stick with premium.
Old Apr 6, 2011 | 08:44 PM
Gizmo's Avatar
Gizmo
I forgot to mention, if you do use 100 octane then your engine will compress the fuel to 93 octane levels regardless.
Old Apr 6, 2011 | 08:57 PM
mini on's Avatar
mini on
www.pure-gas.org
Old Apr 6, 2011 | 09:11 PM
Gizmo's Avatar
Gizmo
Originally Posted by mini on
Oh splendid! NJ isn't even listed on the states with ethanol-free fuel!
I was getting excited for a minute.
ian260
Mar 29, 2017 06:08 AM
minieater
Oct 28, 2015 02:15 PM
Fordgt4
Oct 10, 2015 10:42 AM
cub4bearindiana
Oct 2, 2015 09:45 AM
gnhovis
Sep 28, 2015 04:07 AM
