oil or water temp or scanguage?
Old Jan 9, 2011 | 09:56 PM
Erikka's Avatar
Erikka
The lack of a proper temperature guage of any sort is troubling me and am looking to add some form of temperature gauge to my R57, curious what route those of you have taken....
Old Jan 9, 2011 | 10:03 PM
onefish2's Avatar
onefish2
Scangauge for water temp. Works well.
Old Jan 9, 2011 | 10:53 PM
Eric_Rowland's Avatar
Eric_Rowland
+1 OBDII will give H2O temp, as well as AIT (Air Intake Temp). Oil temp requires a sensor/sender+wiring/receiver. Cost/benefit says H2O works. (I had the OEM oil temp sensor drain plug, but the 3 (?!?!) threads it had gave up the ghost in the oil pan, so I make do with the H2O temp.)
Old Jan 10, 2011 | 05:04 AM
Minidrivr's Avatar
Minidrivr
I use an Aeroforce Interceptor gauge. It doesn't display oil temp on the Mini but it does have 2 analog inputs that could be used to add oil temp. Does pretty much everything a Scangauge II does except some of the trip meter functions. I had a Scangauge II before switching to the Aeroforce.
Old Jan 10, 2011 | 05:09 AM
NMgokart's Avatar
NMgokart
Scangauge II works well for me. One of the best features IMO, is the actual MPH instead of what the OEM speedo shows. Quite a bit of difference. The code reading/clearing function is nice to have and can be used on any OBD2 vehicle.
Old Jan 10, 2011 | 07:49 AM
Porthos's Avatar
Porthos
Do you have a droid phone? If so get this http://www.cravenspeed.com/products/...plete-Kit.html
$50 cheaper then a scangauge and it comes with a mount. I love mine because you can have up to 6 gauges on one screen and there are multiple screens. Plus there is no wire running around you legs like with a scanguage.
Old Jan 10, 2011 | 08:44 AM
Agarwaen's Avatar
Agarwaen
Have an iPhone?
get Kiwi Wifi, and Rev! Does the same thing as Scanguage, and the droid version linked above. lol
Old Jan 11, 2011 | 11:24 AM
Patches's Avatar
Patches
I found these on the Craven web site. I'm considering this even though I do have an iPhone 4 and various scan/tune hardware-software packages. I like the idea of permanent, hard gauges. Requires no drilling, is reversible and matches the stock gauges, including the night backlighting. Pus, it looks cool.
http://www.cravenspeed.com/products/MINI-Complete-Gauge-Kit.html
Old Jan 11, 2011 | 12:36 PM
Melangell's Avatar
Melangell
Onefish2, do you get any cel's with all of the NM plumbing? Beautiful car!
Kimolaoha
Jul 5, 2023 01:04 PM
Cereall
Sep 5, 2019 06:05 PM
Inziladun
Sep 3, 2015 10:35 AM
5904
Aug 27, 2015 10:00 PM
