Aesthetic Creations vinyl issues
Old Jan 8, 2011 | 02:08 AM
Shukie's Avatar
Shukie
I have the oem bonnet and boot sport stripes installed which were made of thick vinyls that were designed to be installed wet. I ordered the bumper sections from Aesthetic Creations and they were very thin and designed to be installed dry. Does anyone have experience with Aesthetic Creations? Because the bumper sport stripes I received were not shaped to match the curvature of the body like the oem ones. As a result I ended up with a lot of wrinkles and bubbles in order to make them look straight and parellel. Am I doing it incorrectly? They also arrived uncut, so I had to cut them to the correct length while installing.
Old Jan 8, 2011 | 06:22 AM
Reebus's Avatar
Reebus
I ordered the stripes to extend mine down the front bumper from them.(see my gallery) Yeah, I did have to cut them to fit, but I guess I expected to have to do that.
Old Jan 8, 2011 | 09:11 AM
Shukie's Avatar
Shukie
Did you cut them into smaller pieces to match the curvature or did you install each piece as a whole?
Old Jan 8, 2011 | 11:16 AM
Fly'n Brick's Avatar
Fly'n Brick
I replaced my OEM bonnet stripes with AE replacements and laid them on wet. I used the flat of my hand to 'help' the vinyl conform to the curve of the bonnet then squeegied real good and only had a couple of small bubbles that went away after a few days in the sun. Using a wetting solution allows for adjustments as the vinyl is laid down and makes it easy to lift it off if things don't look right the first time.
I think everybody's confidence level and temperament have a great deal to do with the DIY success of this project which has shown up in more than one thread. Kinda like talking a two year old into jumping off the diving board. Once he's in the water there's no holding him back.
Old Jan 9, 2011 | 04:52 PM
Reebus's Avatar
Reebus
Sorry it took me so long to respond. I had to cut the individual pieces. It took a while, but they finally got there
Old Jan 9, 2011 | 05:23 PM
Agarwaen's Avatar
Agarwaen
The Aesthetic Creations vinyls are not designed to be applied wet, and thus can be tricky. Applying them wet can destroy them if they are designed for dry only application.
Southern Marylander
Jan 14, 2019 06:05 PM
cawwwtun
May 3, 2016 08:03 AM
AdrenaliNate
Nov 14, 2015 10:43 AM
SolCalMini
Sep 1, 2015 08:19 AM
Knuckle14
Aug 26, 2015 08:10 PM
